Old 01-02-2007, 03:03 PM
DUI DUI is offline
Send a message via MSN to DUI
D16/B16 header question
i'm planning a crv-tec swap with a b16 head. i heard from a friend that there are some headers that are interchangable between d16 and b16 heads. is this true? and what brand? thanks
'92 Honda Civic EX 4DR 5SPD:
AEM V2 intake
Skunk2 intake manifold
DC 4-2-1 2 piece headers
Skunk2 MEGA power exhaust
APC short shifter
Centerforce stage-2 clutch
ATC stage-3 8lbs flywheel
Old 01-02-2007, 03:50 PM
DUI DUI is offline
Re: D16/B16 header question
oh, and would b16 headers connect directly to the existing civic exhaust system (cat)?
AEM V2 intake
APC short shifter
Old 01-02-2007, 04:19 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
No, they are different. And even if the bolt pattern was the same, the height of the block is much bigger for a crv/vtec. Even a B16a header is going to be too short. You'll need one for a B18c or specifically for a B20/vtec. I don't think an aftermarket header will line up exactly with your existing exhaust, the length should be different (either the header is too long or too shorts, can't recall which). But if you're looking for power, the stock exhaust is going to be too restrictive, you should go at least 2.5"
Here's some companies to check out for a header:
http://www.an-r.com/bseriesheader.htm
http://sms-products.com/Headers.html
http://www.hytechexhaust.com/
http://www.dtr-fab.com/product_header_b-series.html
http://www.importpowerhouse.com/cust..._manifolds.htm
Those are just a few companies that make good headers out there. Of course there are other companies that make cheaper ones, but thye don't always give you the best performance.
Old 01-02-2007, 06:13 PM
DUI DUI is offline
on that note, because the gsr b18 makes more horse power would the head also make more HP over a b16 head on the b20? and i'm planning on a jackson racing SC for the b16 head. would there be any clearance problems?
AEM V2 intake
APC short shifter
Old 01-02-2007, 08:28 PM
CivicSpoon's Avatar
There is no Spoon
the gsr head will raise compression slightly, but it shouldn't make that much of a difference. but if u get the sc for the b16a, it won't work on the gsr head (different intake manifold bolt pattern); so pick which head to use beforehand
