Old 01-02-2007, 01:13 PM
mygreenTT's Avatar
mygreenTT mygreenTT is offline
Send a message via AIM to mygreenTT
a/f gauge question
wassapening guys, i haven't posted in while due to being on leave for a long time. moms place doesnt have the uberweb. as for the question, i've done the research thing on splicing into the signal wire on the o2 connectors, and as always, stealth tt's and vr4's are 99% the same but here it goes: i found on stealth316 the signal wire for a 92 stealth tt is yellow but may differ on newer models and so on and so on. on my 93 vr4 is the signal wire the same yellow wire? if anyone has does the install give me a heads up. thanks a bunch.
yea, im just getting around to installing the gauge after having it for a month now.
93 3000GT VR4
blitz dsbc @ 1 bar
blitz turbo timer
autometer boost and a/f gauge on a pillar
greddy type s bov
NGK iridiums w/ NGK wires
3SX DP, 3" stainless single shot
drilled and slotted rotors w/ hawk pads, steel braided lines
supra pump hot wired
SPEC 3 clutch
PTE 550cc injectors
SAFC II
IPS tubular manifolds
evo3 16g snails
converted sidemounts courtesy of oohnoo
built and tuned by jeremy and keith at WSR
Old 01-02-2007, 05:11 PM
Igovert500's Avatar
blue + red light magnet
Re: a/f gauge question
I personally wouldn't even bother. It's a narrowband. Get a wideband o2 sensor if you really wanna know what is going on. As far as the color of the wire goes..I'm not sure. But I would think, you could just use Stealth316 to find the ECU connections for each year. Figure out which pin hte wire you want to tap goes to, and check the color at hte ECU.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 01-02-2007, 05:30 PM
mygreenTT's Avatar
the ecu pins were my next step, i've had the unit out before and its not that hard so i'll probably just do that. 55 is the front and 56 is the rear. wideband i know, i guess i was feeling cheap when i bought it. i'll just wire this one up for a semi close idea now and the wideband is in the so so near future sometime. thanks for the info vert.
93 3000GT VR4
blitz dsbc @ 1 bar
blitz turbo timer
greddy type s bov
SPEC 3 clutch
PTE 550cc injectors
SAFC II
evo3 16g snails
Old 01-03-2007, 07:45 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Narrowbands aren't "semi close". They basically tell you if are above or below 14.7 A/F that is all.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 01-03-2007, 10:26 AM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
That's pretty much how I roll with mine. What's the wideband one tell you? exact numbers?
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 01-03-2007, 10:47 AM
Yes, generally to 0.1 with a range of about 10:1 to 18:1
