Old 01-02-2007, 12:17 PM
cgtomahawk cgtomahawk is offline
96 Voyager Flashing Accessory Lights after Battery Change
I installed a new battery & the accessory lights for the rear window wiper, A/C & interior recirculator blower keep flashing for approx. 15 minutes or about 8 miles before they finally go out. This happens every time I turn the car off & restart. Was not doing this before new battery installed. Is there a reset to correct this? Dealer tells me I need to bring it in for repair.
Old 01-02-2007, 05:17 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 96 Voyager Flashing Accessory Lights after Battery Change
Start the van and turn on the blower. Simultaniously push the top and bottom wiper buttons on the left side of the ventilation control panel for 5 seconds. All the lights on the panel will light up. Then two lights on the left side will alternately flash for about two minutes and you'll hear the ventilation modes cycle. When just the top light on the left side slowly flashes push that button and you're done. All lights should be out and you should be back to normal. Restart the van a few times and make sure. This is the ventilation control calibration test and it resets the ventilation system computer.
The dealer would have called you back in an hour and said "Mr cgtomahawk, you are a lucky man. All we had to do was calibrate the vent system and the fee is only $80." You would have thought ," I'm sure glad these guys have the know how and equipment to save me all that money". The equipment....two fingers, the know how...a couple sentences in a book.
This could be a good press to test for your dealership. Call them and tell them somebody told you I need to do a ventilation system calibration to fix this and you would like to know how. If they tell you thank your lucky stars you have a dealership with some common sense. If not, take your business elsewhere in the future. Cheers.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 01-03-2007, 08:56 PM
direland direland is offline
I am having the same issue and always wondered what caused it. I just tried this method and it appeared to be working. But the two lights alternated flashing for much longer than 2 minutes and never stopped. Would the fact that my AC is no longer connected be a factor?
Old 01-03-2007, 08:59 PM
vipergg vipergg is offline
Pretty hard to do a cooldown calibration if the AC is disconnected ....
Old 01-03-2007, 09:01 PM
I guess I will just have to live with the flashing lights then
Old 01-03-2007, 11:25 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
direland - You don't have to start the van to do this. I just said that to save the battery a little strain. Assuming you disconnected the plug on the compressor, try reconnecting it and redo the test. If it still doesn't work look through this . There may be something there that helps. http://www.allpar.com/fix/codes-climate.html
Old 01-05-2007, 11:38 AM
Smile Re: 96 Voyager Flashing Accessory Lights after Battery Change
RIP, Thanks for the instructions, they worked like a dream. Did exactly as stated, yesterday afternoon & all is in working order. I also posted about replaceing the heater hose restrictor valve & having a loss of heat. This ventilation control calibration also took care of this problem & the heat will roast you out.
Thanks again for the top-notch information & a real money saver
Old 01-05-2007, 12:48 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Hey that's great news and two birds with one stone to boot. I always get a kick out of helping people keep money in their wallets and out of a dealerships hands. Oh and thanks for "posting the fix". Cheers.
Old 01-25-2007, 10:56 PM
buzoman buzoman is offline
I also have the problem with my 1997 Town & Country, I did that test and after it's done, it goes back to flash the AC and interior recirculator blower buttons. How do I Get rid of it? I got great heat on the driver side but cold air only the passenger side ? Please help me!!
Old 01-26-2007, 12:23 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
It's failing the cooldown test. It may have failed because the interior of the van was too cold. Try warming it up for a few minutes first then try the test again. Read the note about half way down here: http://www.visteonclimatecontrolprod...41695_tsbs.htm
Old 01-26-2007, 06:08 AM
Thank you for your help, I'm trying that later today. It's pretty cold here (20 degrees) I'll let you know what happens. Again, Thank you
Old 01-26-2007, 10:07 PM
I went for a drive on the van, and after awhile I ran the test on it, and it got rid of the code. But no heat yet on the passenger side.
Old 01-26-2007, 10:20 PM
chris_warner chris_warner is offline
My 98 Town and country goes thru the process and ends up with the top left light flashing once and the 2nd from top left flashing 4 times and then repeating. How can I fix.
Thanks
