Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-02-2007, 12:57 PM
ASJT3 ASJT3 is offline
Send a message via AIM to ASJT3
Changing Caprice Wiper Arm
Hey guys,
I need to remove the left wiper arm from an '87 Caprice wagon. I can't figure out how to get it off, any ideas?
Thanks,
Alex T
Old 01-02-2007, 02:05 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Changing Caprice Wiper Arm
Originally Posted by ASJT3
Hey guys,
Thanks,
Alex T
There is a little clip below the arm where it meets the splined shaft. Pull this out and pull the arm vertically off of the splined shaft.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 01-02-2007, 10:33 PM
OK, so on one of the arms (looking out the windshield, the right arm) I definitely see a clip, but on the one thats broken, I see no such clip, could they be of different designs?
Thanks,
alex T
Old 01-03-2007, 09:25 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
You might have to "park" the wiper in another position to get good access to the clip, do open the hood, it will give you more room to play. Grab the clip with a pair of pliers and pull it back, which is probably all of 3/16". From there it pulls straight up, which might be a struggle for a few seconds.
Bob
Old 01-04-2007, 01:09 PM
I think what happened is that the clip must have broken off of the arm in question. I can clearly see the clip on the good arm, but on the broken one, the clip is unfortunately absent, only the "pegs" where it should be attached remain. Is there any way of removing this arm then?
Thanks,
Alex T
Old 01-05-2007, 09:21 AM
bobss396's Avatar
If you have the new arm already, compare it and try to identify the little ears that need to be pulled back on the old one. Open the hood to give yourself more room. Needle nosed pliers should be ok.
You still might have to fight to get it off, unclip the tension spring on the underside of the arm. From there it might need a little coaxing with a big screwdriver. Place a block of wood on the cowl and pry against that.
I had one extremely stubborn one once, wound up cutting most of it off with an abrasive wheel.
Bob
Old 01-14-2007, 05:55 PM
1968 Pontiac's Avatar
1968 Pontiac 1968 Pontiac is offline
BTW, before you pull the clip, lift up the arm, then pull the clip out, then release the arm to hold the clip out while you try to fiddle the arm off the post.
1949 Chevrolet 1433 (Canadian 1 ton cab and chassis single rear wheel pick-up truck)
1968 Pontiac Parisienne (rust free survivor)
1973 Buick Centurion (four door hardtop; engine will be donated to our 1949 1 ton truck)
1989 Chevrolet K3500 RC/LB (454 & single rear wheels)
1991 Chevrolet Caprice Classic (police cruiser clone)
1992 Chevrolet K2500 EC/SB (almost rust free daily driver)
1998 GMC C1500 EC/SB
