Old 01-02-2007, 01:33 AM
Laoboiracer14 Laoboiracer14 is offline
need help again!
okay..so i got a new power cable for the amp and now its the amps fuse thats shorting and not powering my sub..what should i do?
Old 01-02-2007, 03:26 AM
Darrick147's Avatar
Darrick147 Darrick147 is offline
Send a message via AIM to Darrick147 Send a message via Yahoo to Darrick147
Re: need help again!
You may not have a stable ground or ur power cable is touching metal somewhere and thats whats causing it to short.
Old 01-02-2007, 08:47 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
does the fuse blow immediately after hooking it to the battery, or does it blown only after the amp has turned on ?
Old 01-02-2007, 09:10 AM
PlayStation3 PlayStation3 is offline
or did you just upgrade your power wire and not get the proper ground wire for the amp
