Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-01-2007, 09:53 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
89 olds 307 developed lifter tap, low oil pres
My 89 caprice wagon with the olds 307 vin Y engine with 93k recently developed what sounds like no oil is getting to the lifters. I recently changed timing chain and water pump and put together without cam button and spring. developed the noise the next day. i drove the car around for a day with the clacking, hope i did not damage it.
I then reinstalled the cam buttom but it did not help the problem.
I then installed a manual oil pressure gauge and ran the motor
30 psi at 2000 rpm but then it dropped off to 18 - 20 psi
at idle was 10 psi but then started to fluctuate around 7 - 10 psi
I dropped the oil pan and it was totally clean, cut open oil filter, totally clean, took apart oil pump, seemed good.
I took off left side valve cover and spun pump with a drill, got the same pressure readings spinning pump with drill. 5 out of 8 rockers were getting oil yet there still seems to be a restriction someplace.
Has anyone heard of a similar problem with this engine?
Any suggestions would be appreciated.
Old 01-02-2007, 12:25 AM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: 89 olds 307 developed lifter tap, low oil pres
I had the same problem, turns out I had a collapsed lifter. I found that out during dismanlting the engine for a rebuild. Can you pinpoint it to a single rocker. Try a valve adjustmet, it acted as a temporary fix to my knock. Each rocker when in the relaxed position shoild have just enough play to spin the push rod. If the pushrod can be moved up and down, even a little bit, its out of adjustment. Mone was so bad, the rocker felt as if it was practically ready to fall out of the engine.
Old 01-02-2007, 12:38 AM
Blt2Lst's Avatar
Thanks for the reply, this is a roller motor and has no way to adjust valves at rocker arms.
I still suspect a blockage in the oiling system, question is where?
Old 01-02-2007, 03:21 PM
Blt2Lst's Avatar
would a collapsed lifter cause low oil pressure?
Old 01-02-2007, 05:00 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
No, but low oil pressure will certainly cause collapsed lifters. It is difficult to determine what is causing an oil pressure loss without disassembling the engine. If the oil pressure loss was due to a lifter, that oil pressure has to go somewhere, and in this case that would be up the pushrod to the cylinder heads. If you see a LOT of oil flow up there with a valve cover off and the engine running, this is a possibility. My personal guess would be a main bearing, especially if you can hear a 'thud' from the bottom end of the engine while it's under load.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 01-02-2007, 05:45 PM
Blt2Lst's Avatar
I did not hear any thud or knock.
it sounded like clacking lifters.
also, oil pressure builds to 30psi then drops off to 18 - 20psi while rotating with a drill motor.
my next step will be to remove the intake to inspect further, then maybe removing cam if the main bearings are ok.
Thanks for your help
Old 01-02-2007, 05:59 PM
silicon212's Avatar
Confoundingly Lucid
Main bearings require removing the engine from the car as these are what the crank sets in.
Old 01-02-2007, 09:21 PM
PeteA216's Avatar
Quote: My personal guess would be a main bearing, especially if you can hear a 'thud' from the bottom end of the engine while it's under load.
In my '89 GMC w/ 112k, when I put it in gear, and whenever the engine is under even a slight load I get a sever rattling that sounds as if its originating from the bottom of the engine. When cold I get 30+ PSI, when warm its only 10+ PSI... Thats a bad thing right?
Old 01-02-2007, 11:17 PM
silicon212's Avatar
Confoundingly Lucid
Bearing wear, either or both mains and rods, will manifest as a 'rattle-knock' when the engine is first fired after sitting for several hours. This sound is hard to explain, it almost sounds like it's going to blow up shortly after it fires. If you have this, along with low oil pressure, it might be a good time to think about a rebuilt engine. 10psi is never good for any engine, methinks.
In late-'87, early '88, I had a 1972 Impala Custom coupe that had been rode hard and put away wet, and the engine was pretty much 10-7. It had oil pressure, but it also had 3 wiped cam lobes and two blown head gaskets (out of 2 total LOL), along with copious amounts of cylinder head wear. Throw in a little piston wear, and this thing got 15MPG on the highway, on BOTH gas and OIL. Yes, that's 15 miles per GALLON! The car was a smokescreen that would have made James Bond proud, and lots of liquid oil shot out the tailpipe along with the smoke.
So, I had this 305 that I had gotten from my Dad - I put it together, installed it in the car in place of the one-foot-in-the-grave 350, and was happy. Yes, it was a 305, but it ran on all 8 cylinders and didn't smoke, and had more power than the terminal 350 ever did (it was the aforementioned L65 165HP 2bbl). Just one problem - less than 300 miles after installing the engine, the oil pressure dropped into the 10psi range at idle hot, and never exceeded 15-20PSI. The oil looked like metallic paint. Being a kid of 17, and not having a job, I put it together with available used parts and wound up grabbing a crank that was ever-so-slightly-bent, and it was eating the mains, which were then becoming suspended in solution in the oil. It did this with two sets of bearings before I replaced the crank (on money lent to me by a neighbor).
What does that have to do with the above? Probably nothing, just had to share a similar experience is all.
Old 01-03-2007, 11:52 AM
PeteA216's Avatar
Now that you say somethign about startup, immediately during the initial rev, theres a coinciding rattle type know that lasts a split second. But a less severe rattle that I described initially comes at idle and just above any time the engine is under load (In gear) no matter what the temp. Now it's got a TH 400 bringing the power to the rear wheels through a 3.42 rear end, and I drive roughly 150 miles a week on the express way to work and back, the wole time the engine holding a steady 2500-3000 RPM because of the gearing, no overdive, and no torque converter lockup. How much worse does this make my situation?
Old 01-03-2007, 03:01 PM
silicon212's Avatar
Confoundingly Lucid
Don't rev it when you start it! Give it a couple of squirts before you turn the key and let it idle into life. The higher RPM can't help you out here!
Old 01-03-2007, 03:41 PM
PeteA216's Avatar
No no no no, I never rev it at startup, its got EFI, so it does it all on its own, and when its really cold out (winter) it holds an idle of 2000 RPM for a few minutes that can't be kicked down, because its trying to warm itself up... A down side of computer controlled engines I guess.
Old 01-03-2007, 04:35 PM
Blt2Lst's Avatar
I just found out that running motor without cam buttom can cause cam to walk forward. i now need to remove cam and lifters and inspect for damage.
how will i be able to tell if a lifter is bad other than physical damage.
thanks for the help
Old 01-03-2007, 05:04 PM
silicon212's Avatar
Confoundingly Lucid
thanks for the help
If your engine has hydraulic roller lifters, then yes you absolutely need the button. Pull the lifters out and check them, and also pull out and check the camshaft itself. If a lobe comes off the roller, the damage is usually lethal to both the cam and lifter.
Also, if the cam moves far enough forward, this can result in low oil pressure as you are exposing the oil passages to the air instead of a journal!
Old 01-03-2007, 09:47 PM
Blt2Lst's Avatar
Excellent info.
I plan on diving in on saturday to find out.
Will keep you posted
Thanks again
