Old 01-01-2007, 08:40 PM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
BAM! lights are gone
90 CRX DX 250,000 miles
I was driving last night for work and I turn the lights on and off a lot from parking to on and last night it was all bad...I was driving I turn the lights from parking to headlights and it's all good then I turn them off and back on and allllll the parking lights don't work anymore...no interior lights, the clock doesn't dim like it supposed to, no corner lights or running lights in the back but the headlights still come on, it's getting old I know but could it be a relay or switch? I don't think it's a fuse but i'll check
Old 01-02-2007, 02:10 AM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
Re: BAM! lights are gone
grounds? fuse? relay? bulbs?
-tony-
2000 honda s2000
Old 01-02-2007, 12:17 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Certainly sounds like the relay, the headlights are on a different one, and the clock isn't dimming. Get under the dash by the fuse panel and flip the lights on. Listen for the relay to click, Also remove it and check to make sure its working. Put voltage to 2 contacts (keep trying different combos till its right) and see if it clicks, then when it does, check for continuity between the other two contacts that you aren't putting power to.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 01-02-2007, 04:30 PM
turns out it's the fuse...but it's not just the fuse I tried just putting a new one but it blew it also, so there must be a short somewhere but I have no idea where it could be since there are so many things connected
Old 01-02-2007, 07:23 PM
FrodoGT's Avatar
Check for corrosion or water in the bulbs, it can short out a light.
Current project:
Rio Red 91 hatch.
Old 01-04-2007, 04:41 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Could be the switch is bad.
