Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 01-01-2007, 07:23 PM
caddyman379 caddyman379 is offline
Smokey mornings..
1992 Olds Cutlass Ciera 3.3V6 4spd 4T60
147, 333 miles
Doesn't have to be morning, anytime it hasnt really been warmed up enough.
Oil is clean and recently changed, transmission fluid is dirty but not losing any.. Car smokes a bit when started cold and lasts until maybe 125ish and then it diminishes to light light smoke. How normal is this? I don't remember it being this severe last winter.
The only thing I can think of would be that over the summer I drained and flush the cooling system and refilled it. I did not use a supplement tab, however I did use a small amount of alumaseal. The reason I say this, is because ever since then the hoses seem to get harder quicker then they did before. The only time the upper would be hard was when the t-stat was open, and now its hard maybe a minute or so after you start the car.
Radiator cap compresses and feels like its at about 16lbs.
Any ideas?
Am I just worrying here or what guys
Thanks, Rich
Old 01-01-2007, 07:27 PM
firemachine69 firemachine69 is offline
Re: Smokey mornings..
What colour smoke and does it smell?
Old 01-01-2007, 07:32 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
When its cold out your exhaust will smoke due to condisation evaperating as the exhaust heats up.
After it gets to running temp, it shouldnt smoke much if any.
I guess it will smoke some if its around freezing temp, but thats the same reason hot pipe cold outside.
1999 Grand Am SS 3.4 OHV
Old 01-01-2007, 07:44 PM
its white, and smells normal. its the type that lingers around and diminshes after its been in the air for 10 or 15 seconds.
forgot to mention: car runs very well, does not miss or stall and shifts properly.
do the hoses getting hard sound normal to you? i know its supposed to be pressurized..
it does take and give back to the res.
Old 01-02-2007, 09:00 PM
Ian Szgatti's Avatar
Ian Szgatti Ian Szgatti is offline
it really does sound normal, but for your own satisfaction, you could have your exhaust gases analyized.
