Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 01-01-2007, 04:05 PM
sylbry sylbry is offline
2001 v6 surging, stalling, and tach issues
While driving sometimes the car will act as if it is going to die then surge. This always coincides with the tach jumping up to 4,000 rpms and then jumping to 8,000 rpms when you give it throttle.
Twice it has died while sitting at a stoplight. No sputtering, just dies. Once it started right away, once it took 30 seconds.
Once the engine light came on.
This problem just developed in the last two weeks and I would like to get it taken care of ASAP.
After searching other threads I think the problem is with either the EGR valve, crankshaft sensor, or fuel pump pressure regulator.
Just wondering if anymore more knowledgeable can offer a suggestion before I attempt to change all three.
Thanks for your help,
Bryan
Old 01-01-2007, 04:07 PM
Re: 2001 v6 surging, stalling, and tach issues
I forgot to mention the car has 60,000 miles and I just recently chance the PCV valve and plugs.
Old 01-01-2007, 04:20 PM
Just went to start the car after it 1) stalled on me and 2) after I got it started surged 30 seconds later.
It took 30 seconds to get it started and the engine light is on.
Old 01-01-2007, 05:12 PM
maxwedge maxwedge is offline
A990 racer
Get it scanned for the code, step one.
Old 01-01-2007, 06:31 PM
I just cleaned the EGR valve and the engine light shut off.
Old 01-01-2007, 08:54 PM
Well that didn't work. Stalled again. The engine light did not come on this time however.
Old 01-22-2007, 12:01 AM
KeninCanada KeninCanada is offline
Did you get this sourted out? What was the verdict? My 2001 just started the same thing. I was thinking ECM but need to read more threads.
Old 01-22-2007, 09:52 AM
It was the crankshaft position sensor.
Old 01-22-2007, 12:47 PM
Many thanks for the quick reply.
