Go Back   Automotive Forums Car Chat > Chevrolet > Corsica
Old 01-01-2007, 12:22 PM
mcrosby mcrosby is offline
Need Help w/ Work Car: 2.2L died won't start
Help! I was driving down the highway @ 65 mph. when my car died suddenly, just like you turned the key off, but all of the instument lights and gauges stayed on. I coasted to the side of the road and tried to start the car many times. It turned over, but never fired up. I towed the car home and used my OBDII scanner to check the codes. I retrieved the P0342 code, "Camshaft position sensor circuit". I removed the sensor and inspected it. Yep, it is a sensor alright. I took it apart and found that it is actually a Hall I.C. sensor and there is really no way to check it. I replaced the sensor ($71.99) and the spark plugs. Still no luck. I do have fire at the plugs, and I have gas. When I replaced the plugs, they were wet with gas, and I disconnected my gas line to the fuel rail while I turned the engine over and lots of gas came out. Also, I can smell gas after I try to start the car numerous times.
Can anyone tell me why I never get fire from any cylinder, nor do I get any back firing. If you have spark and gas, why no combustion? I checked the compression with my thumb, with one of the plugs removed, and there seems to be at least some compression.
Thank you for your help,
Mike
Old 01-01-2007, 07:36 PM
Re: Need Help w/ Work Car: 2.2L died won't start
I found out, by looking at the rocker arms, that the camshaft is not turning. The timing chain is apparently the problem. Thanks anyway.
Mike
Old 01-18-2008, 04:31 PM
K_millar K_millar is offline
how did you see the rocker arms? Did you just take the valve cover off?
KMillar
