Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 01-01-2007, 11:00 AM
eurobeaner's Avatar
eurobeaner eurobeaner is offline
Send a message via MSN to eurobeaner
Wierd problem!
I have a 93 del sol Si i put a turbo kit on it about 6-7 months ago. Heres the problem if i rev the motor let off then hit the throttle again it cutsd out and if you keep it held the car will just rev down and die but if you let off it will stay running and drive fine it also does it when driving and shift it to second or any gear and hit the throttle to quick it will do it. If you easy into every gear it wont do it. Ive replaced the throtle body put new injectors in it plugs. I have no idea any help would be awesome Thanx!
95 Civic EX
H&R sport springs
KYB AGX Struts
Energy Suspension Poly Bushings
15" black VSR's on nitto NT450 not-so extreme performance 205/50/15
CAI
http://www.cardomain.com/ride/2489240/1
Old 01-02-2007, 01:40 AM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: Wierd problem!
Is it tuned or are you, God help us, running an FMU and a MAP bypass?
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 01-02-2007, 05:12 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Wierd problem!
Sounds like a fuel issue to me also.
Old 01-09-2007, 04:57 PM
eurobeaner's Avatar
Re: Wierd problem!
No i took the fmu off after i got the adj. fuel pressure regulator, and injectors. and yes i have a mapbypass for right now until i get the computer chipped.
95 Civic EX
H&R sport springs
KYB AGX Struts
CAI
Old 01-09-2007, 05:31 PM
NA is Best!
Re: Wierd problem!
Sounds like you're leaning out real bad. Just a reg won't fully compensate for boost. IMO, take the turbo off untill you can pay to get a real ECU tune done. It's worth every penny.
Old 01-09-2007, 09:25 PM
eurobeaner's Avatar
Re: Wierd problem!
im not gonna take it off im just gonna buy a new walbro pump cause i think its messed up cause sometimes it comes on when you turn the car on and sometimes it dont
95 Civic EX
H&R sport springs
KYB AGX Struts
CAI
