Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 12-31-2006, 09:17 PM
1996Chreokee 1996Chreokee is offline
2001 Crown VIc PI Steering problem
Hello,
I have a 2001 Crown Vic PI... with 128k miles on it... Every once in a while I notice that the steering wheel gets harder to turn and does return to center.. then all the sudden the problem goes away.... Weather does not affect it nor does how long the vehicle been running... SOmetimes it does it and sometimes it does not...I would greatly appriciate any help...
Old 01-01-2007, 01:05 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 2001 Crown VIc PI Steering problem
Check the little u joint under the master cylinder. Disconnect the shaft and see if the u joint moves freely. If it is stiff, use trans fluid or penetrating oil to free up shaft. If that does not cure it, ll the steering connections,(ball joints, pitman arm, idler arm, and tie rods) need checked for stiffness. If these are all OK, the box needs replced.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 01-04-2007, 06:37 PM
thank you ...oiling the u joint worked... thanks for the help
Old 01-05-2007, 05:16 PM
way2old's Avatar
TOKEN HILLBILLY
Thanks for the reply. It may help someone in the future.
