Old 12-31-2006, 01:17 PM
firestud2829 firestud2829 is offline
Turn signal concerns
I have a 2000 Jimmy 2dr, 4.3, auto. I noticed the other day that my left turn signal flashes a lot fater than the right turn signal. I checked the hazard flashers and they flash at the same speed. I dont really see this as a problem more than as an annoyance. What could be causing the left signal to act stupid? Should I be more concerned about this? How do I repair this?
Old 12-31-2006, 05:15 PM
muddog321 muddog321 is offline
AF -Advisor
Re: Turn signal concerns
Check the bulbs or the flasher canister behind the glove box.
Old 12-31-2006, 07:31 PM
old_master's Avatar
Advisor/Moderator
A burned out bulb will usually cause the flasher to flash slower on the side that has the burned out bulb. If you connect a trailer, they will flash faster because you are adding bulbs, (resistance) to the circuit. The flasher unit is nothing more than a self re-setting circuit breaker.
Old 12-31-2006, 10:22 PM
I did a quick check of the bulbs and all are functioning. Haven't had time to take a look at the flash canister yet. But I will update when I check it out. Thanks for the quick responses.
Old 01-01-2007, 10:02 AM
DINO55's Avatar
DINO55 DINO55 is offline
Firestud,
The rear tail light bulbs are a duel filliment bulb, you need to replace the left bulb. Sometimes the filliment will break loose and lay across the good filliment giving you a false reading (They work with the hazzards)
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 01-01-2007, 10:48 PM
DelCoch's Avatar
DelCoch DelCoch is offline
I thought it was just the opposite. Flash fast with a burnt out bulb and slower when adding extra lights on a trailer??
Old 01-02-2007, 05:33 PM
old_master's Avatar
Advisor/Moderator
The flasher unit is a circuit breaker that resets itself. When the turn signals are turned on, the current that is drawn to operate the bulbs goes through the flasher unit. When the bimetal element within the flasher reaches a given temperature, it expands and opens the circuit and the lights turn off. When the element cools, it contracts and closes the circuit, and the lights turn on.
Each flasher is designed to control a certain number of bulbs. If there are fewer bulbs, (or burned out bulbs) it will take longer for the element to heat up. If there are more bulbs, it will heat up and open the circuit faster.
Old 01-02-2007, 05:41 PM
Wow what a simple fix! I just knew this was going to take lots of time and even more $$. Thanks folks for all the info. I changed the bulb and all is well. And I got to use some of the new Craftsman goodies that the Wife bought me for Christmas!!
Old 01-02-2007, 11:01 PM
blazee's Avatar
blazee blazee is offline
Problem?
That's the way that mine did, the left side flashed faster when one of the left rear bulbs was blown.
Others have had the same experience:
http://www.automotiveforums.com/vbul...d.php?t=584379
http://www.automotiveforums.com/vbul...d.php?t=369477
http://www.automotiveforums.com/vbul...d.php?t=362400
Old 01-03-2007, 12:39 AM
DelCoch's Avatar
I think there might be two different types of flashers. Maybe the ones on newer vehicles flash slower when a bulb is burned out. I know the old style flashers draw the extra current that was used by the burnt out bulb, thus the flasher heats up faster and the contacts break sooner. Basically, this was designed into the flasher to let people know a bulb was burned out.
