Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 12-31-2006, 12:21 PM
thjackson2 thjackson2 is offline
Thumbs down Oil Pressure Valve delta 88 Leaks
can you put the Oil Pressure Valve in wrong i put 2 Gaskets on and still leaks.it is a 1989 Delta 88 leaks at the oil filter Adapter wher it bolts on the block
Old 12-31-2006, 01:18 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Re: Oil Pressure Valve delta 88 Leaks
Year?
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 12-31-2006, 02:04 PM
Smile Re: Oil Pressure Valve delta 88 Leaks
Originally Posted by Alibi
Year?
1989
Old 12-31-2006, 02:50 PM
maxwedge maxwedge is offline
A990 racer
Leaks from where? Seems we are asking you more questions than you are please post all the pertinent info one time.
Old 12-31-2006, 02:58 PM
Cool Re: Oil Pressure Valve delta 88 Leaks
at the seal on the Oil filter Adapter wher it goes on the block i have replaced the Gasket 2 times still leaks
Old 12-31-2006, 03:24 PM
A990 racer
. Check the mounting surface with a straight edge to see if is warped on the adapter body, and the ft cover, the spring can go either way. No sealer here either.
Old 12-31-2006, 03:34 PM
you think i need a new Adapter opcorn:
Old 12-31-2006, 03:43 PM
A990 racer
Check the flatness like I suggested first. Make sure no nicks or burrs on either surface also.
Old 12-31-2006, 04:03 PM
it is warped
