Old 12-31-2006, 02:29 AM
paxfam1 paxfam1 is offline
Front End???
1998 Blazer
Okay so for sometime I have had this front passenger side noise, its like a humming noise, only when moving at like at least 20mph, and when I am on a curvy road when the vechile leans off that side the noise stops. But when it is straight the noise is there. Also not sure if this is related but when I go around a corner some times, and only some times I get a big pop/clunk from that same side, that usually occurs at low speed like 5-6mph and I can really feel it. Could anyone diagnose this from my description?.............
Old 12-31-2006, 06:32 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Front End???
Sounds like your hub bearings are starting to go...
Old 12-31-2006, 01:04 PM
Re: Front End???
I was thinking the same thing, is there anyway to check them before I dissasemble the whole thing? Any tips on dissasembling the hub?
paxfam!!!!
Old 12-31-2006, 05:12 PM
muddog321 muddog321 is offline
AF -Advisor
Re: Front End???
No dis anything - 1 piece so have to buy a complete hub assembly. Three 18mm bolts hold it on.
Old 01-01-2007, 12:33 AM
Re: Front End???
seriously????? Why would they make it so the entire assembly has to be replaced and not just the bearing?
Old 01-01-2007, 07:02 PM
Re: Front End???
What size socket do I need to break that main hub nut?
Its not possible to repack that bearing is it? Even if I could go a few more weeks that would be good, dont have alot of money right now.
Old 01-03-2007, 12:16 AM
Re: Front End???
alright, picked up a new bearing/hub assembly today, and was woundering what size socket I need to get that main spindle nut off, its big and I kneed to get a socket. What else holds it on?
Let me know
paxfam
Old 01-03-2007, 12:59 AM
Cloud Strife Cloud Strife is offline
Re: Front End???
Let me know
paxfam
36mm is what mine takes.
1999 Blazer 4x4 LS "Blackie"
Monroe Reflex Shocks
Moog U/L Ball Joints
K&N FIPK Gen 2 Cold Air Intake
Flo-pro Soundpro exhaust
Optima Redtop
132k miles and still rolling....
Old 01-03-2007, 04:27 AM
AF -Advisor
Re: Front End???
Yep, 36mm and all stores sell them usually as hardened black 1/2" drive - loosen with the wheel on the floor before jacking and may need a cheater bar to break the rusted nut free. Then after raising Blazer and removing the hub bolts you will need a large 2 jaw pilley to pull the hub off the axle or a block of wood and 3 lb hammer (don't mess the threads up). Of course the caliper mounting bracket then the rotor has to come off first (18mm again).
Old 01-12-2007, 12:56 AM
Re: Front End???
Yes, replaced wheel hub/bearing and its all good now........The hardest part was getting the old hub off the shaft.
Ended up beating the old hug off with a mall...........3lb hammer lol
