Go Back   Automotive Forums Car Chat > Plymouth > Fury/Gran Fury
Old 12-30-2006, 10:08 PM
ricochet_rita@epix ricochet_rita@epix is offline
HELP..Inline fuel filter on Plymouth Fury 111???
Hi everyone,
I am a newbie to this forum.I just was given a 1970 Plymouth Fury 111.Does anyone know if this car has an inline fuel filter?Any help will be greatly appreciated.
Thank You,
Respectfully,
Rita Marie
HAVE A SAFE AND HAPPY NEW YEAR!
Old 01-01-2007, 10:26 AM
KManiac's Avatar
KManiac KManiac is offline
Re: HELP..Inline fuel filter on Plymouth Fury 111???
Yes, your car has an in-line fuel filter, or at least it should. The filter is mounted between the outlet of the fuel pump and the carburetor. Now you didn't say what engine you have, but that shouldn't matter that much. The fuel pump should be an engine mounted, mechanical unit, so it should be under the hood. First, find the fuel pump under the hood. Then find the steel line from the output side of the pump and follow it towards the carburetor. Or you can locate the fuel line into the carburetor and follow it back to the fuel pump. Either way, you should find the fuel filter. Now, I am assuming that your car is factory stock and not altered from that configuration. If you car has been extremely modified, what I said may not be true. Good luck and let us know what you find.
"This car may be old, but it will still climb Kirker Pass at 110!"
1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible
Old 01-01-2007, 12:19 PM
Thank you,KManiac...I found the one from the carb to the fuel pump.I was wondering if there was another one from the fuel pump to the gas tank.It is stock.The only thing that is not is the motor.Which I put a 340 in it,from a 69 Duster.THANKS Again and HAPPY NEW YEAR...
Rita Marie
Old 01-09-2007, 08:46 PM
rhandwor rhandwor is offline
Their should be a sock filter on the sending unit in the gas tank for your fuel gage.
Do you have a problem or you just doing maintenance?
