Old 12-30-2006, 09:40 PM
tastylatinkitty tastylatinkitty is offline
92 jimmy ABS light on Service Engine light on
OK.. just bought a 1992 Jimmy which was rebuilt in 1996 with a new tranny and engine.. has 151k miles on it.. drove it home about 100 miles and now the check engine light is on also the ABS light is on all the time.. no pulsating or soft pedal going on.. just light is on.. the e brake light is off...
Went to Auto Zone... had them try to run a code on it.. but they can't because the cigarette lighter isn't working.. just wondering if there is anything i can try other than a fuse to get the cigarette lighter working?
Old 12-31-2006, 07:09 AM
DINO55's Avatar
DINO55 DINO55 is offline
Re: 92 jimmy ABS light on Service Engine light on
tastykitty,
ABS LIGHT: could be dirty hub wheel sensor, or a bad hub sensor...
Provided you have a good power wire to the lighter, you either have a bad ground going to it, or the lighter is shot. New lighters are less then $10 bucks...
Good luck and post back...
Dino
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 01-01-2007, 03:53 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Try jumpering the top righthand hole on your regular diagnostic port at the lower dash under the steering wheel to the 2nd from the left bottom hole then turn the keyswitch on. Eric & I got a single ABS flash, pause, then 4 flashes..1-4...code 14 to start with so you can probably expect that. Count your flashes and we'll talk about them.
All help gratefully accepted.
Old 01-01-2007, 04:32 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
I've never heard of needing the vehicle's cigar lighter (not to be confused with a cigarette lighter) to read the codes. Auto Zone used to hand out a two pronged flat key to read power train codes that looked like the tool used to remove the cleats on golf shoes.
The jumpering method described by Chris works good. For power train codes jumper the two upper right pins with a paper clip then turn the ignition switch to the run position. Watch the Service Engine Soon light for trouble codes. It will start by flashing one long and two short flashes to indicate a "12" or start of file 3 times followed by any stored codes. At the end of any codes stored it will flash the 12 again to indicate end of file. For ABS codes use the same procedure but jumper the upper right to the second from left on the bottom. Code 14 seems to indicate the start and end of file on the ABS codes.
