Old 12-30-2006, 09:15 AM
mikaz mikaz is offline
Problem with airbrush and acrylics
I´ve been banging my head to wall with this problem. I use airbrush ( try to ) with acrylics paint which i have dilluted with water but the problem is when i try to airbrush it almost only thing that come out is the air. Paint might come out little while and then it stops if i move the trigger back and forth it spits little paint and it might even spray evenly for a while. I´ve tried several dillution levels and air pressures but it havent helpt. Is the problem water´s surfacetension which blocks the paint in or what might be the problem??
Old 12-30-2006, 09:27 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Problem with airbrush and acrylics
It doesn't sound like a thinning or pressure issue (and it's certainly not something like surface tension). The paint is not feeding, probably due to intermittent blockage. To me, it sounds like a cleaning issue- that you have some old gunk in the nozzle which is not letting paint evenly flow through.
What kind of airbrush are you using, and what kind of acrylic? There's probably something better to thin with other than water.
PHOTOBUCKET SUCKS
Old 12-30-2006, 09:28 AM
ales's Avatar
ales ales is offline
Forza Schumacher
Which acrylics paints were you using?
You really shouldn't thin them with water, use proper thinner. And secondly, your problem seems to be that the paint is too thick and clogs up the nozzle. You are sure you're using acrylics, right? Improper thinner/paint combinations usually coagulate the mixture and clog up the airbrush.
Old 12-30-2006, 03:57 PM
Khier Khier is offline
It sounds as if you are using pressure cans. If yes, get rid of it and use a proper compressor. Otherwise it seems a blockage problem as mentioned above. Maybe the paint you used was too old and started to solidify, or perhaps needed better mixing to disolve large particles.
Old 12-30-2006, 04:07 PM
MA8 MA8 is offline
Try to use proper thinner instead water, it must help you.
