Old 12-29-2006, 11:59 PM
Johnniemccoy Johnniemccoy is offline
Power Window Pooped Out
96 Lumina, 30k miles. My drivers side window quit working - it's the kind that goes all the way down when you push the button for a second or so. The switch makes clicking sounds when I push it. I removed the tray, unplugged the switch and brushed one side of the contacts (couldn't get to the other sides) with a gun barrel cleaning brush (all I could find that would fit, somewhat). No luck with that. I'd like to know the order of easiest, cheapest things I could try next.
Thanks
John
Old 12-30-2006, 10:26 AM
gw84's Avatar
gw84 gw84 is offline
Send a message via MSN to gw84
Re: Power Window Pooped Out
My windows started acting goofy right before they completely went out. They would go down, but not back up Turned out to be just the switch that needed replacing. Your case could be diffferent though. I don't think there are many options for what could be wrong....it's probably the switch or the motor...what else could it be??? p.s. switch is much cheaper than the motor...I'd start there. You should be able to test the motor somehow to eliminate it as the problem..
This ain't your grandma's car!!
Old 12-30-2006, 11:30 PM
I guess I could find some way to test the switch, then, if I can get to it, try jumping the motor. Guess there's no obvious quick fix...lol.
Thanks
John
Old 12-31-2006, 09:19 AM
gw84's Avatar
I don't know the exact details of how to do it (safely) so I don't want to mislead you. I remember that when my window failed, they somehow hooked the car's battery to a wire from the motor and the window went right up. I got a switch from the dealer ($20) and have had no problems since. That was on a '93 vehicle so the price may not be accurate. Also, if you have access to a junk yard, you can get switches there for a couple of bucks. I got my rear switch from the j/y and it works beautifully. It's a risk, but also a lot cheaper!
Old 12-31-2006, 09:21 AM
gw84's Avatar
Just thought I would clarify on testing, I believe they hooked the battery to [one of] the wires that connects to the window switch.
Old 01-11-2007, 09:11 AM
kevinb70 kevinb70 is offline
Send a message via AIM to kevinb70 Send a message via Yahoo to kevinb70
I've also had a switch go out causing the Drivers window to stop working. 98 tho.
