Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-29-2006, 10:25 PM
38ffems 38ffems is offline
Need some help with intake gasket issue
I am pretty sure I have a bad intake manifold gasket. Its a rough idle and I have the whistling noise that was described. I am pretty sure I can handle this, but wanted to know from people who have done this if this is a shady tree mechanic fix or should i have a proffessional do this. I believe Felpro is the company that makes these, any brand I should keep an eye out for or stay away from?
Old 12-30-2006, 08:02 AM
surferfletch surferfletch is offline
Re: Need some help with intake gasket issue
If you can turn a wrench you can do it! Let us know how it goes. I used the Felpro gaskets from Advance. For reference, take a few pics of the engine bay before you dig in.
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
Old 12-30-2006, 10:02 AM
Ok I will, I am probably going to tackle this tomorrow but will post up when its done. I really hope this fixes my problems because just like i have read in other posts, i think the hole has gotten big and now it idles LIKE CRAP! when driving normal it runs pretty decent though just when I slow down and park.
Old 12-30-2006, 01:15 PM
How many miles on your rig? Might be worth checking your plugs.
Old 12-30-2006, 08:27 PM
I just replaced all the plugs and they are gapped to i think .42 i dont really remember what i gapped them at. I am almost positive that its the gasket because everything that is happening is exactly as described by other people. How long does it normally take to replace the gasket and is there anything I need to look out for or be careful of?
Old 12-31-2006, 07:59 AM
You should be able to do it in a couple of hours. The first time I got the engine torn down that far, I was really slow, making sure I marked where everything went. There is a lot of stuff bolted to the upper intake. The second time I tore it down, it went very fast. Just don't drop anything down into the engine when it's apart! Maybe someone with the DOHC engine can chime in. I have the '97 SOHC engine.
Old 01-11-2007, 10:29 AM
Ok got it fixed, was both upper and lower intake gaskets, holy crap what difference. It cost me $250 but I don't have a torque wrench and I am very sketched out about pulling the engine apart at this point. Still learning though.
Old 01-11-2007, 04:31 PM
Hard to break anything with this job. You do have to be careful when tightening bolts into aluminum. I did mine without a torque wrench, though. Glad you got it done!
