Old 12-29-2006, 10:22 PM
billibong's Avatar
billibong billibong is offline
99 Blazer Front Half shafts??
Been awhile folks, but I am going to be replacing both front halfshafts on my 99 Blazer 4X4. Both outer CV boots are leaking, and I figure it is easier, and probably cheaper, to replace both half shafts.
Is there any tricks or tips that I can get from some of our fine folks out there? I know I have to pull the front hubs off to remove the outer splines, what is involved in pulling the shafts out of the front diff? I figure on replacing the fluid when I change out the shafts.
Thanks in advance for the help.
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
Old 12-30-2006, 09:00 AM
Cloud Strife Cloud Strife is offline
Re: 99 Blazer Front Half shafts??
Well I still have yet to get the splines out of my broken front differential when I had to replace my differential.
But in my experience, you may be better off popping the support that holds the hub on away from the ball joints. Otherwise you may not have enough clearance.
If you decide to continue on with this, I would really look hard any parts that may need replaced b/c you will have most of your front end loose at this point.
1999 Blazer 4x4 LS "Blackie"
Monroe Reflex Shocks
Moog U/L Ball Joints
K&N FIPK Gen 2 Cold Air Intake
Flo-pro Soundpro exhaust
Optima Redtop
132k miles and still rolling....
