Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-29-2006, 09:08 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
4G63 Head break in
Okay, I already searched. Found a few opinions. Some say to take it easy for the first couple hundred miles. Some say drive at or below 3k rpms for 15-20 minutes to break in the cams. Others say just make sure every contact spot is lubed with oil or assembly lube and boost away.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 12-29-2006, 09:14 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: 4G63 Head break in
Kevin told me no break in, just go for it. I dont know though, I wouldnt be overly worried about it. Just make sure you go hog wild on the assembly lub and it wouldnt hurt to take off the valve cover and pour or a quart or so over the shit when you fill er back up with oil.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 12-29-2006, 11:44 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
I talked to my shop about this extensively.
The best way to break in your motor is just to drive it normally. You don't want to drag race the hell out of it at first, but you need to let it see boost, so just drive it like you would drive it normally. Don't pussy foot it, but again don't beat the hell out of it.
1991 GSX 2.3 Stroker
Old 01-01-2007, 08:53 PM
NateS's Avatar
I know the break in procedure for a block but, I'm just talking about the head here. I think I'm with you on this one thor. I am just going to lube it up nice and pour some oil with the valve cover off and go for it. I was told with roller rockers there is no need to "break in" the cams.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 01-02-2007, 06:55 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Did you soak the lifters in oil before you put them in?
95 Talon TSI AWD
97 Eclipse GST
Old 01-02-2007, 08:27 PM
NateS's Avatar
The shop that I had machine my head also installed the lifters. I do not know if he soaked them in oil. They are slick(I think he put wd40 in/on them) but, other than that I do not know. Since they just slide out I guess I can just slide em out and soak em up. Any other suggestions?
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 01-03-2007, 04:01 AM
Yeah just take take them out and stand them upright in a coffee can or something and dump in some oil and let them soak for awhile. I usually let them sit for a day.
95 Talon TSI AWD
97 Eclipse GST
Old 01-03-2007, 03:58 PM
NateS's Avatar
Cool thanks. Should I completely submerge them?
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 01-03-2007, 04:00 PM
I always do.
95 Talon TSI AWD
97 Eclipse GST
Old 01-03-2007, 05:50 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Is that so the lifters get the oil inside?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-04-2007, 05:01 AM
Yes sir, otherwise if they're new and haven't been pre-oiled or they have sat for a long time, the oil sometimes drains out of them and they run dry, and you woudln't want that to happen now, would you?
95 Talon TSI AWD
97 Eclipse GST
