Go Back   Automotive Forums Car Chat > Toyota > Supra > Maintenance
Maintenance Have questions? Find answers. Help out fellow Supra owners.
Old 12-29-2006, 03:34 PM
charliesangel charliesangel is offline
Desperate for headlight help
I never dreamed I would join a car board and I see this isn't a very busy forum but I am in desperate need of help. I have an 85 that the headlights stopped working on. So far we have replaced the headlight relay, bulbs, and sockets. We are down to either needing a new switch or a wireing problem. Does anyone have any suggestions of what to do now? How do we test for either problem? This is our only car, my husband goes back to work in a few days and will have to drive after dark , there is no one close that he can ride with and we can't afford the $80 an hour shops want just to look at it. Any advice will be greatly appreciated even if it is a temperary fix and not the "right" way to do it.
Old 12-29-2006, 11:53 PM
TcmaBoy's Avatar
TcmaBoy TcmaBoy is offline
AF - Advisor
Re: Desperate for headlight help
Get a multimeter and check the wires. Check for voltage at the lights and proper ground. If there is no ground then repair the broken wire. If no voltage at the lights chase back through the relay and switch until you find the power. Repair the break accordingly.
Don't you SAS me boy.
Please wheel responsibly.
http://www.treadlightly.org/
Old 01-09-2007, 02:09 PM
KimMG KimMG is offline
AF - Advisor
Use a meter to check the connections going through the turn signal switch. It is a common point of failure on many makes of cars.
