Go Back   Automotive Forums Car Chat > Toyota > General Discussion
Old 12-29-2006, 01:12 PM
95RSV's Avatar
95RSV 95RSV is offline
Seized spark plugs
I just replaced all of my spark plugs and they were really overdue. All of them were seized but not to a point were it was extremely difficult to twist off. I am pretty sure that their is some build up around the thread inside the chambers. I know that there shouldn't be anything inside the chambers especially dirt. Should I use some kind of cleaner to wipe off the build up or a little bit of rust wouldn't hurt.
Thanks in advance
Tsudo N1 Catback
Custom 4-2-1 Header
Custom Hi-Flow Cat
Custom CAI
Exedy Organic
Fidanza Flywheel
NGK Iridium
Tokico HP Suspension
ADR DV8 Sandblack Rims
Nankang NS-1 Rubber
Old 12-29-2006, 09:06 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Seized spark plugs
Don't mess with anything inside the plug holes. Replace the plugs with ones with antiseize compound on the threads and leave well enough alone.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 12-30-2006, 01:40 PM
95RSV's Avatar
I used NGK Iridium. The spark plugs that were previously in there were Bosch Platinum. I actually thought anything less than platinum would seized but apparently platinum do seize and hopefully iridium will not.
Thanks again
Tsudo N1 Catback
Custom 4-2-1 Header
Custom Hi-Flow Cat
Custom CAI
Exedy Organic
Fidanza Flywheel
NGK Iridium
Nankang NS-1 Rubber
Old 12-30-2006, 01:43 PM
Brian R.'s Avatar
Resident Chemist
The electrode material (iridium, platinum, etc.) has nothing to do with whether the threads seize or not. Put some antiseize compound on the threads of all the plugs of any electode composition.
