Old 12-29-2006, 12:36 PM
Dan2006 Dan2006 is offline
1998 Grand Caravan Power outlets
Simply,
The power outlets (front and rear) shut are off when the ignition key is off. This isn't bad but when the kids are using the outlet for their accessories and we stop to get gas etc, I shut the motor off. I'd like to modify this so that the outlets have power all the time. They will be fused! I'm thinking this is an easy modidication. Perhap either repositioning a wire or repositioning a fuse.
Any takers?
[email protected]
Old 12-29-2006, 07:35 PM
Stretch58 Stretch58 is offline
Re: 1998 Grand Caravan Power outlets
[quote=Dan2006]Simply,
Any takers?
I think the outlets are hot in the accessory position of the ignition switch also. Allows usage with ignition off. Might save you a lot of work.
Retired USAF/ Nuclear Plant Controls Dude
Had Recently
1996 Caravan 3.0 Great Car
2005 Impala 3.8
Now
2000 GC 125K 3.3
2006 T&C 3.8
Old 12-29-2006, 08:13 PM
earlyrizr earlyrizr is offline
replace the 1" square relay in the PDC with part #82301039 from the dealer and it will change it from keyed to constant hot.did this to mine for charging the cell phone.it just pulls out and the new one pushes back in.I've heard of others using a jumper and getting the same results,but for me this was safer.
Old 12-29-2006, 08:37 PM
Earlyrizr's post has to be the best solution. Just make sure they kids turn off all their stuff before they get out of the car.
Had Recently
2005 Impala 3.8
Now
2000 GC 125K 3.3
2006 T&C 3.8
Old 01-09-2007, 06:19 PM
Earlyrizr's post was the best solution for me as well. The relay jumper cost me $8.56 and I installed it in less than a minute. Both front and rear power outlet are always hot. Thanks for the help.
