Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-29-2006, 12:04 PM
Xeiros's Avatar
Xeiros Xeiros is offline
Send a message via AIM to Xeiros
Does boost stay constant till redline?
I was under the impression that it does, but then again I don't know the range of the T25 turbo. I've noticed that it starts to spool around 2300 RPM's or so, and thought it stayed till redline .
After installing my aftermarket boost gauge today, I noticed I will run a consistant 13 pounds of boost till around 5500-6000 RPM's where it creeps back towards 10 pounds or so. If it's not supposed to do that (which is my guess) then I've got it pin pointed to my BOV which I found leaks a bit (big suprise). If it is supposed to do that...well...foohy.
Old 12-29-2006, 01:25 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Does boost stay constant till redline?
The t2small simply runs out of "uumph" (sp?) as you approach redline. It will never hold full boost all the way through the range, it's just not big enough.
95 Talon TSI AWD
97 Eclipse GST
Old 12-29-2006, 02:02 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Well if it's creeping down than it's probably just because the stock wastegate is a piece of shit.
1991 GSX 2.3 Stroker
Old 12-29-2006, 02:52 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
t25 holds boost untill about 5500 rpm, it plumits with the VE curve. Nothing you can do about it.
DSM geek
Old 12-29-2006, 06:53 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Mine does the exact same 15 psi max then down to 10 psi. 3rd gear it creeps to 17 and i hit fuel cut at 4500 but im sure if it kept goin itd be down to 10 psi by redline
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 12-31-2006, 02:21 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
engine is using more air than the turbo can provide
now - 2000 civic
soon - 2002 is300
Old 12-31-2006, 04:05 PM
Xeiros's Avatar
I see. Well thats good to know I guess. No point running till redline if I'm going to lose boost 1000-1500RPM's before I hit it.
Old 12-31-2006, 05:23 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Even on my car with a 16g I can only hold 21psi untill 5000 then it drops off to 16
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 01-01-2007, 10:26 PM
yep, a 16g on a 2.4 is like a T25 on a 2.0
now go get a 50 trim
now - 2000 civic
soon - 2002 is300
Old 01-02-2007, 12:04 AM
blk_srt's Avatar
Thats the plan
Mods:
Old 01-02-2007, 12:28 AM
airFS airFS is offline
I think someone should buy one of these....
http://www.turboneticsinc.com/turbo_gtk.htm
96' Talon tsi AWD
Mods: greddy upper and lower intercooler pipes _ greddy type rs bov _ K&N intake _ 3" turbo back exhaust _ ngk spark plugs & wires _ garrett T-28 turbo _ greddy oil catch tank
Old 01-02-2007, 02:12 AM
the compressor housing looks like a gimick to me, besides the slots which have already been in use
now - 2000 civic
soon - 2002 is300
Old 01-10-2007, 04:26 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
my T-25 use to spike to 23psi and drop off to about 16psi. How do you think i was running 13's on a T-25, boost the shit out of the t-25 lol
I burned up 3 t-25's but it was worth it running 13.73 with only $600 at that time in my car, and most of that cost was the exhaust. Turbos were free so i did not care lol.
13.7 run with a t-25 and stock clutch at a 5500 rpm launch.
http://videos.streetfire.net/video/b...0eb019e5a9.htm
One thing i might add also i had about 30 runs with my stock clutch and alot on the street and never burned up my clutch completely.
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 01-22-2007, 01:00 AM
bryan_bigd's Avatar
bryan_bigd bryan_bigd is offline
i have a 16g and i hit peak at 26 lbs and then it will level at 24. well atleast until i hit fuel cut out. then it drops fast. but i can run 19 lbs constant with no drop and i hit max boost at 3300-3400 rpms. my brothers t25 will hit max boost at 21lbs and level out around 14 or 15 lbs. that with a few mots, exhaust, big intake pipe, and upper intercooler pipe. crushed 1g bov. so you can milk a little more power out of that turbo then 10 lbs.
1995 talon tsi 10-26lbs of boost boost controller k&n intake 550cc injectors 255 fuel pump ported head 3 angle valve job hks metal head gasket arp head studs racing manifold evo3 16g ported turbo 34mm wastegate 3in turbo back exhaust no cat act 2600 clutch 7.9 lbs fly aem 9.3 plug wires irradom plugs lowered 2 in camber correction all four wheels 2 3/4in upper intercooler pipe greddy rs BOV racing hard intake pipe apexi NEO fuel manigment system oh and it has the 6bolt motor
