Old 12-28-2006, 12:24 PM
Kalidor Kalidor is offline
Send a message via ICQ to Kalidor
'01 Caravan SE whining noise
Hello and good morning!
Now I've searched this forum about the problem I am experiencing and I am not sure that any of the posts I read really apply. So please excuse me if I am posting about something that has already been answered.
This Caravan has 68k miles and up until recently the whining noise I hear only happened when cold starting the car on a cold day. Just yesterday it also started to make some kind of a rattling sound in addition.
The original whining noise lasts only for a few seconds when cold starting, the new rattling sound also only happens when cold starting but lasts quite a bit longer (about 20 seconds). Can any of you advise me on what is going on with my vehicle?
Live - nature's way to keep meat fresh.
Old 12-29-2006, 08:02 PM
twistedtech twistedtech is offline
Re: '01 Caravan SE whining noise
Just a little more info would be great.Have a few ideas,or thoughts I should say.Engine size,climate yadda yadda.
If it ain't broke.......screw with it till it is.
Even at a Mensa convention,
Someone's the dumbest person in the room.
Old 01-01-2007, 12:43 PM
Sorry for the omission of more details... Engine is the 3.3 V6, climate... well, upstate NY, rather wet this year.
The rattling went away when it got a little warmer again, the whining from the left side of the engine is still there. Even with a hose it is rather difficult to pinpoint where it comes from, since it only lasts a few seconds.
Old 01-04-2007, 01:52 PM
Rawtorque Rawtorque is offline
When you say left do you mean driver's side? If so, check your automatic Transmission fliud level. This is best done in Neutral, warmed up, with engine running, so you need a helper to stand on the brakes for safety.
NEVER DEPEND ON WHEEL BLOCKS OR PARKING BRAKE WHEN DOING THIS!!! Get a helper.
If you haven't changed the trans fluid in a while the filter could be plugged. Use a quality filter, Mopar or Transtar, and ATF+4 fluid. Viscosity changes in old fluid can make cold fluid flow worse.
Now, if it's the left side looking at the front bumper (front passenger side), it may be the power steering, serpentine belt idler bearing, alternator bearing, etc.
Flushing the power steering is a good idea if you've never done it. It also builds up crud.
Old 01-06-2007, 09:55 AM
Stu the blue Stu the blue is offline
I have the same problem and live in the same sort of place.Mine just sounds like the starter not disengaging upon cold start up, normally when it is below freezing point.Through the summer we have no trouble with it, and the same when the engine is warm. I am waiting for the starter to show signs that it is wearing out before replacing.
Old 01-09-2007, 09:09 AM
appstech appstech is offline
Is the noise comming from the alternator pulley? A good way to check this is to rev the engine up to about 3000 or 4000 rpm and then shut it off. This vehicle is designed to allow the alternator to internally spin or coast to a stop. If there is a noise after shutdown for a few seconds then it is most likely the alternator deocupler creating the noise. 2001 was the first year (V6 only) that came with the alternator decoupler pulley. This special pulley has a spring and clutch inside and helps reduce noise and vibration while extending belt life. These pulleys can be replaced on their own (without having to replace the entire alternator). They are available through Goodyear. The goodyear part number is 49911. You will need a 17mm hex allen key on an impact gun to remove the alternator decoupler. It is not very hard to replace. If you would like to read more about the decoupler function you can go to this website.
http://www.tendeco.com/website/decou...ecouplers.html
