Old 12-28-2006, 11:02 AM
puma215 puma215 is offline
Unhappy 91 civic dx stubles
it will run and stay running. it idles almost smooth. it started just out of the blue going down the highway, when i came to a red light it started. as I take off it will go but acts like if i'm in the wrong gear. it will do this in every gear. when i get to higher rpms then normal and let off the gas just a little bit, it will smooth out until i switch gears and it does it all over again. i've replaced the fuel filter and spark plugs. the pump was replaced about 6 months ago. any suggestions?
Old 12-28-2006, 11:39 AM
jusg19 jusg19 is offline
Re: 91 civic dx stubles
1. Change your fuel filter
2. clutch need adjusting?
Old 12-28-2006, 01:16 PM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
fuel injection service.
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
Old 12-30-2006, 01:13 AM
I've replaced the fuel filter and spark plugs. the fuel pump was replaced about 6 months ago. it stays running, there are no engine lights, its been driving like this for about 2 wks now and nothing has got better or worse. would it be injectors even though the engine light hasn't came on? it changes gears fine so i dont think it could be the clutch. just when i'm driving if i let off the gas just a little in smooths out until i try to speed up again.
Old 12-30-2006, 05:37 PM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
so it studders. hmmm i would say fuel injectors.
-tony-
2000 honda s2000
Old 12-30-2006, 05:38 PM
what kinda gas are you using?
-tony-
2000 honda s2000
Old 12-30-2006, 07:44 PM
bowtieboy12 bowtieboy12 is offline
money says its plug wires. had this happen, spark cant make the jump at low RPM's, but has more power to jump the gap at high R's. could just be loose, or corroded, mine were split. check all connection points then inspect for splits and cracks.
Old 12-30-2006, 09:58 PM
is the gap on the plugs correct? how bout your cap and rotor?
-tony-
2000 honda s2000
Old 12-31-2006, 01:20 AM
why not talk alittle different problem then. dizzy. yes dizzy. if its not getting good spark its not gonan function properly. and yes honda dizzy suck. why not check that. mine took my injectors down with it when the dizzy went.
06 cbr 600 f4i
91 civic hatchback.
Old 12-31-2006, 10:35 AM
ozzfreak ozzfreak is offline
I had this exact problem a few weeks ago, I changed all kinds of stuff, and what finally fixed it was the spark plug wires. Now, it runs smooth as ever. Hope this helps.
Old 12-31-2006, 04:10 PM
if it turns out the dizzy is bad go with this.
http://cgi.ebay.com/ebaymotors/BRAND...61505212QQrdZ1
-tony-
2000 honda s2000
Old 01-08-2007, 06:15 PM
squidlips's Avatar
squidlips squidlips is offline
I'm finding I have a similar problem. The main difference is that when my car runs poorly, all my running lights and turn signals are on. Also, to add some confusion, if I unplug my tail lights, the engine dies.
I think I need an exorcism.
Old 01-08-2007, 07:33 PM
not to be rude but it would help more you made your own thread. and add some more details.
-tony-
2000 honda s2000
