Go Back   Automotive Forums Car Chat > Nissan > Older Pickups
Old 12-28-2006, 12:24 AM
russ67mike russ67mike is offline
93 engine swap with a 96 engine
Im swapping out my 93 engine with a engine from a 96 pickup. Im almost done but ran into a probelm. I need a obd2 to obd1 conversion wire harness. Does any one know where I can find one for a nissan?
Old 12-29-2006, 06:39 PM
zanegrey zanegrey is offline
Re: 93 engine swap with a 96 engine
did you just put in a long block or did you try to drop a whole working engine in???
if you did a long block you would use all original perirpheals so you would not need to upgade anything...
if you dropped the whole working engine the you are going to have to switch the whole wiring harnes and ecm as well as all sensor associated with the newer engine ..
i do not know of a kit that you can buy that ill allow you to plug and paly...
[email protected]
