Old 12-27-2006, 11:21 PM
PlayStation3 PlayStation3 is offline
parallel wireing
ok i think i have my subs wire in to parallel which is what i want. but i want to make sure.
i have the jumper connect a + and- leaving the a + on the far left and a - on the far right then with the, connecting to the 1 channel amp that should be parallel right.
oh this is for dvc 2 ohm version type r
Old 12-28-2006, 12:26 PM
bjboertje's Avatar
bjboertje bjboertje is offline
Re: parallel wireing
couldn't understand what you just described, but both your + should be connected to the + on the amp, both - connected to the - on the amp.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 12-28-2006, 09:23 PM
jtvyper456's Avatar
jtvyper456 jtvyper456 is offline
Send a message via AIM to jtvyper456
If all else fails, www.rockfordfosgate.com and check the wiring diagrams!
1995 Camaro
40 Series Flowmaster
2 Kicker Comp 05CVR 122 (Dual 2Ohm Voice Coils)
^Kicker ZX550.2 Amplifier^
Old 12-29-2006, 08:18 AM
i used rockford diagram i mostly checking to see if i did it right
Old 12-29-2006, 08:24 AM
alphalanos alphalanos is offline
If youre trying to get a 1 ohm load then you should have the two negative on both coils connected then connected to the neg on the amp. the same with the positive.
96 EJ6. Future home of boosted B18C1.
Old 12-29-2006, 02:30 PM
um that would give me a .5 ohm load, 2 ohm dvc. the jumper is on + and - in the middle and the amp is feeding the + and - on the outside
Old 12-29-2006, 02:59 PM
bjboertje's Avatar
one dvc 2 ohm sub or two dvc 2 ohm subs?
what jumper?
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 12-29-2006, 04:27 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
There are no jumpers in a parallel setup only in series, in parallel the wires whould go pos-pos to the amp pos and neg-neg to the amp neg. This will net 1 ohm load on DVC. IF you add the other in then it goes to .5ohm.
use this it even shows how the wires should be on the sub.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 12-29-2006, 05:00 PM
jtvyper456's Avatar
Wire is just like the diagram looks like and you'll get the power load it states.
1995 Camaro
Old 12-29-2006, 11:36 PM
theres 2 dvc 2ohm ones
Old 12-29-2006, 11:45 PM
What amp do you have, depending on the model and brand you should be able to hook it up. Unless its 1ohm mono block.
Cardomain
Old 12-30-2006, 08:09 AM
Octane R 15.0:1 isn't there a way i can just hook up a dmm to it and see the ohm value it is showing?
Old 12-30-2006, 09:54 PM
Wow that amps only 2-ohm stable, your only option is to get it to 8-ohms, unles you want to put down for a new amp.
You could try and check it with a DMM cause even when they say there 4-ohm its never a perfect 4-ohm its sometimes 3.66 same with all other ohm ratings. But if possible id suggest either a different amp or sub if theres a return policy on them, if not we can see what can be done to make it work. also is it for a single sub or 2. If you go 4 ohm if you have a single then you should be in the realm of about 325 rms.
Cardomain
Old 12-31-2006, 09:24 AM
now will this give me a 2 ohm load
Old 12-31-2006, 08:37 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
NO ... that's series wiring. If you want parrallel, you need a "jumper" between the 2 +'s AND the 2 -'s on EACH speaker. Unfortunately, you have dual 2 ohm VC's. Each speaker can be wired to be a 1 ohm or 4 ohm, the amp has a pair of outputs that are wired in parrallel already, so it will see a 1/2 ohm load if the speakers are wired in parrallel or 2 ohms if the speakers are wired in series.
