Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-27-2006, 08:15 PM
Nayr747's Avatar
Nayr747 Nayr747 is offline
60k mi. Timing Belt cost
Don't know if this is "performance" or not. I called a couple shops and was quoted 470 for JUST the timing belt and nothing else, and 770+ for timing belt, water pump, cam seals, and acc. belts. Just wanted to know if I'm getting ripped off or not. Another shop said $1000 for JUST the timing belt. LOL!
'99 GSX, 5-speed, 60k miles: Greddy filter / RRE uicp / 1g bov / Autometer boost gauge / Injen-copy intake / Megan DP (not installed)
Coming soon! Thx to Blackcrow & nova1313! http://dsm-one.org/
Adopt pets in need! http://www.petfinder.com/
Old 12-27-2006, 08:49 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: 60k mi. Timing Belt cost
Rip off. You can do it yourself for much much cheaper. Probably will cost about $300 for everything at MOST!!
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 12-27-2006, 09:14 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Have you been known to swing a wrench? I would just do it yourself. Its kind of a pain in the ass, but its really not hard. Parts are cheap, its the labor they are boring your ass out with. If you cant, I would post up on a local DSM board, I bet someone would be willing to come help you out.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 12-27-2006, 09:26 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
AT LEAST by the parts yourself... I just bought parts for a new head swap. Check this out...
Topline water pump kit $57
OEM timing belt $70
OEM hydrolic timing belt tensioner $74
Replacing the acc. can be a pain in the ass but, I'd rather do it myself than pay someone to do it.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 12-27-2006, 10:07 PM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
yeah, if you follow the directions on VFAQ.com it'll be easy as pie. but whatever you do, make sure you get the mitsubishi timing belt, timing belt tensioner and water pump.I went with a checker timing belt trying to save about 40 dollars and it cost me 2 sets of valves. NOT WORTH IT,
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 12-27-2006, 11:14 PM
Nayr747's Avatar
I always thought doing a timing belt would be pretty hard, but maybe I could give it a shot. It's just sometimes I can be a complete retard and f something up bad. I'm gonna check vfaq (didn't even think of that). Thanks guys!
Old 12-27-2006, 11:22 PM
david-b's Avatar
Dave is THAT guy
Where do you live? Anyone local?
75 Monte Carlo
Old 12-28-2006, 02:46 AM
Nayr747's Avatar
I'm in Seattle. I don't think the people on posdsm would help me... lol. I printed the vfaq but haven't read through it yet. Do I need any special tools? I dont have air tools. But I can buy the cheap ones like the taps. The dsm was the first car I worked on at all so I'm just getting experience as I go. Eh, if I f it up, at least I gave it a shot.
Old 12-28-2006, 03:29 AM
Thor06's Avatar
Jizzed In My Pants
You will need a special tool to reset the tension, or you can have one made from one of those super long batter tie down bolts. Theres something in the VFAQ about it.
I am so glad I get to do all that shit while the new engine is out of the car. I would probably put my head in a vice if I had to do another in-car T belt job.
Old 12-28-2006, 03:14 PM
NateS's Avatar
You do not need the special timing belt tensioner tool to do a timing belt job. Trust me last one I did I did not use the tool. Just follow the directions in VFAQ. A timing belt job is not hard at all just time consuming and lots of finger work. If I was you I would go buy a Haynes manuel. I printed out the VFAQ pages and ended buying a Haynes manuel anyway.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 12-29-2006, 02:19 AM
Nayr747's Avatar
Well I've got the Chiltons manual, and factory service manual. I might just buy the Haynes too. Does it have a better timing belt part?
Ok, well Ive got a couple questions:
1) How much time would it take a complete novice to do it?
2) What to support the engine with? A jack and a piece of wood on the oil pan? Is there any way this could dent the oil pan because I've been lucky enough not to crankwalk so far.
Old 12-29-2006, 02:34 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
for not using a special tool, I've never used one and never will and have done probably 10+ timing jobs on my own car and others.
A timing belt job will definitely be dependant on how good you are with your hands and figuring things out. I know it took me awhile the first time to get the timing correct. I would guestimate with taking everything apart to completely together about 6-8 hours on the high side. I can do it in 2, but I've done it more than a few.
95 Talon TSI AWD
97 Eclipse GST
Old 12-29-2006, 05:27 PM
NateS's Avatar
It took me a good day to do it. I supported my engine with 2 two by fours spread out on my jack. It did not dent my oil pan. You just have to be extra careful. If your good at following directions and finger work than it should not be too hard for you but, I promise you will get frustrated at least once...
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 12-29-2006, 11:48 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
If you have never done one, I would advise you to have a friend help you your first time. He doesn't have to be an almighty DSM god, but someone with a good general knowledge of cars and car maintenence, IE someone who has changed a timing belt before. Once you do it once you can do it again easy. But it's one of those things that if you fuck up you are going to end up paying for it.
1991 GSX 2.3 Stroker
Old 12-30-2006, 11:53 PM
Nayr747's Avatar
Well, I dont know what to do now. I don't really have any friends that are good with cars. My bro's friends are all mechanics or work at body shops, but I dont know if they'd help me (or f something up), and they all hate mitsu.
On a side note, my gf told me she's past 120k and hasn't changed her belts EVER! As in it's the same belt that they put on the car when it was built, lol. Her mom told me she had over 200k miles on her car before the original belt snapped. Honda must make some great belts or something.
