Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 12-27-2006, 04:45 PM
ltc86's Avatar
ltc86 ltc86 is offline
Tps
I saw once a method of checking the tps with a volt meter, by sticking a paperclip in where the green wire enters the connector, I have tried sticking many different metal objects in the connector, and grounding every possible place, but can not get a reading. Is there any other way to do this. I want to replace the tps, but if I can't get a voltage reading to adjust the new one, it won't function properly, or will it? thanks for any help.
Old 12-27-2006, 05:13 PM
sreilly77's Avatar
sreilly77 sreilly77 is offline
Re: Tps
when i had my 95 town car i replaced the TPS by just screwing on the new one. i didn't make any adjustments to it or nothing. and that was over a year ago and i never had any problems with the way the car idled at all.
Sean
Old 12-28-2006, 08:03 PM
junk yard doggie's Avatar
junk yard doggie junk yard doggie is offline
Re: Tps
I had trouble with the tps sensor on my 86 T-Bird. The engine kept reving up in gear when I came to stop. I just replaced it and made no adjustments, that corrected the problem.
Mike
Old 12-30-2006, 08:21 PM
rhandwor rhandwor is offline
Re: Tps
If you watch the bare spots where the old one came off and put the new on in exactly the same place you should be fine.
