Go Back   Automotive Forums Car Chat > Chrysler > 300M
Old 12-27-2006, 02:23 PM
bambambam's Avatar
bambambam bambambam is offline
2000 passenger door sticks
had my 2000 300m since November, great car but the passenger door sticks when opening from the outside. If you bump the door (like with your knee) while pulling up on the handle it pops right open. No problems from the inside
Is there an easy way to adjust this? I spotted an opening and what appears to be an allen screw just below the latch, is this for adjusting?
Any info would help....
bam
Old 12-28-2006, 07:58 AM
tinmanwpk tinmanwpk is offline
Re: 2000 passenger door sticks
I have never heard of a door hinge problem with our M's. You didn't say if it was a front or rear door. Check a couple of things: 1) at the bottom of the door are three screws holding the plastic door panel in place. Sometimes these break and need to be fixed. If this is the cas get back to me and I can help; 2) check the gasket and see if it need to be pushed back into place. Sometimes it gets pulled out a little. Maybe spray a little silicone on it to make sure it doesn't cause sticking.
TinMan
99 M Cypress Green, performance rear sway bar, Brembo rotors w/CT3 pads, tint, Sirius, K&N intake, debadged, many other mods.
