96 k1500 turn key wont start.jumper wire to starter relay starts??
I have a 1996 K1500 that you turn the ignition to start it does nothing.You can leave the key to the run position and use a jumper wire in 2 of the holes the starter relay goes into and the truck starts right up.Also the blower motor does not work now anymore after the truck quit starting the regular way with the key.Sounds to me like the ignition switch but would like to hear from someone else that has run into this problem before to confirm this.The parts store thought it could be a fusible link causing the problem.I dont think so but had to throw that in just in case.Thanks Born
Re: 96 k1500 turn key wont start.jumper wire to starter relay starts??
The starter relay control circuit goes like this.
From the Ign A under hood fuse to the ign sw to the crank fuse (#8 10a) in the IP fuse block to the nuetral safety switch to the relay coil to ground. No mention of a fusable link. It's not the IGN A fuse as that suppies the motor power thru the relay when pulled in. So it's probably one of the other four or wiring that's causing your problem.
57 Chevy 210 65 Olds 442 Convertible (Another one sold) 75 GMC Vandura 3/4 Ton 1999 K2500 Old Body Style Suburban (Gone but not forgotten) 05 Dodge Ram 3500/5.9 Cummins 2012 Toyota FJ Cruiser |
Stupid Fix Techs! My brother in law gave me all the info told me what he did and didnt do.Well I drove a few miles to find out that it was just one of the positive battery cables to the battery was not making contact like he said he checked out.Oh well something simple like alot of times it always is.Thanks
Good job and thanks for posting back. In this "computer" age it's sometimes the "basic" things that need to be looked at 1st.
