Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-27-2006, 08:34 AM
FastJack FastJack is offline
Engine racing
I have an intermittant problem with my 1997 3.2 engine. Sometimes it when I come to a stop at will idle at 3000 rpm and then slowly come back down. Other times it will die. I am thinking it may be the mass airflow sensor but before I shell out $150.00 I would like to feel better that this is the problem.
Jack
Old 12-27-2006, 03:06 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Engine racing
There is a rubber boot on the throttle cable that over time breaks down and gums up the wire which can cause the throttle to stick (search the site for more info).
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 12-27-2006, 03:10 PM
Isuzu Guy
Re: Engine racing
http://www.automotiveforums.com/vbul...hrottle+rubber
-Ryan
Isuzu Moderator
Car Show Tips
Old 12-27-2006, 06:39 PM
trooperbc's Avatar
trooperbc trooperbc is offline
Re: Engine racing
before you go through that whole regimen, i suggest you read or get read the OBDII codes, which if any, will point you in the right direction.
as to the rubber boot, it wouldn't cause the engine to die (but it damn near scared the death out of me when mine stuck open -- yikes, lots higher than 3k too)
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 12-28-2006, 01:29 PM
surferfletch surferfletch is offline
Re: Engine racing
Maybe clean the IAC valve too. It's mounted on the front of the TB. It has 2 screws and one plug to undo.
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
Old 12-29-2006, 08:46 AM
Re: Engine racing
Thanks. I will check these suggestions out over the weekend and get back to all of you. Happy New Year.
Jack
