Sony DCR-DVD505 DVD Camcoder Bundle
Up for sale is a slightly used Sony DCR-DVD505 DVD Camcoder. This camcoder is top of the line in its set, it features a 4 megapixel integrated came, which can tape pictures while recording. It takes mini-dvd's which are 1.4 gigabytes in storage space and can hold up to 40 minutes of video, depending on the mode you select, in the highest resolution mode it will record only 20 minutes while in the medium resolution mode it will record 30 minutes. Well, here are the specs from the Sony (http://www.sonystyle.com/is-bin/INTE...=feature&var2=) site:
2.1 Megapixel (Gross) ClearVID™ CMOS Sensor 1/3" CLEARVID™ CMOS Sensor with 1910K (effective) pixels provides stunning detail and clarity with exceptional video (up to 530 lines of horizontal resolution) and still image performance. The Megapixel technology enhances your digital videos and digital still (3980K) photography performance. 3.5" Wide Touch Panel SwivelScreen™ LCD Display2 (211K Pixels) The 3.5" Wide (16:9) LCD screen2 provides excellent viewing clarity with improved resolution. The high resolution 211K pixel LCD screen rotates up to 270 degrees for multiple viewing angles providing sharp, detailed images for monitoring or playback, and the widescreen format makes shooting in 16:9 mode and composing shots even easier. Smooth Slow Recording By increasing the record rate from 60 fields per second (fps) to 240 fps for 3 seconds allowing you to capture 3 seconds of fast motion and play the video back in 12 seconds. This is great for analyzing a golf swing or a viewing a bird in flight. 10X Optical/120X Digital Zoom The optical zoom helps to bring the action close up from far away. In addition, the Digital Zoom interpolation means that extreme digital zooming is clearer, with less distortion than previous types of digital zooms. Professional Quality Carl Zeiss® Vario-Sonnar® T* Lens Carl Zeiss lenses have an advanced optical multi-layer coating that offers less glare and flare with increased contrast. This results in vivid image brilliance, true-to-life color saturation and perfect renditions of subtle tones. The additional T* coating on the lens further reduces unwanted glare and flare. Active Interface Shoe Provides a location directly on the camcorder to which to add optional accessories while providing power and two-way communication to those accessories. Battery Information At the touch of a button, battery information is displayed on the LCD screen when charging and when the camcorder is turned off. The display will show how much the battery is charged (approximately), in 10% increments and the recordable time left when using the LCD screen or in the viewfinder. Digital Still Memory Mode with Memory Stick Duo™ Media130 Capture still images up to 2304x1728 resolution, directly onto Memory Stick Duo™ Media for easy transfer to PCs for emailing, printing or sharing with other compatible Memory Stick™ devices. Dolby Digital 5.1ch Recording The DCR-DVD505 will record in Dolby Digital 5.1ch surround sound with a built-in microphone. By recording in 5.1 channel surround sound you can now experience your home movies with active sounds coming from all directions. Enjoy your personal home movies the way you experienced them while recording. DVDirect Compatibility The DVDirect Multi-Function DVD recorder models MC3 and VC30 offer direct connection to the HDD Handycam via USB 2.0 and can record all the video on the hard drive to DVD or just what’s new and changed since the last DVD burn. What’s more, the video can be recorded from the HDD Handycam to DVD at up to 3X speed. DVD Format Video Recording1 The DVD recording format delivers digital picture and sound quality comparable to that of MiniDV, but on DVD. Playback of the DVDs couldn’t be simpler. After finalizing the disc in the camcorder, the disc can play back in most DVD Players, computers and even PlayStation® 2 video game consoles. DVD-R/RW and +RW Compatible4 The DCR-DVD505 is compatible with a variety of DVD formats allowing the easy of use and simplicity found in DVD Media. With DVD+RW media there is not a need to finalize the disc (minimum recording required). Simply remove the disc and insert the media into a compatible DVD Player3. Easy Handycam Button Using a camcorder can be intimidating for some people, so with a press of the Easy Handycam button, most of the advanced features of the camcorder are “locked out" leaving only the buttons essential for recording operational. Manual Focus Allows the user to manually adjust the focus of the camcorder using the touch panel. Manual focusing also allows the user to control the focus in difficult situations where either the environment or the subject does not allow the camcorder’s auto focus to perform optimally, such as when shooting through a window or in a crowded environment. Super NightShot® Infrared System With Sony’s NightShot Infrared System you can capture natural looking video, even when shooting in low light. Record subjects up to 20 feet away using the built-in infrared system. On Screen Zoom and Record Buttons For addition control of the camcorder, the DCR-DVD505 features Zoom and Record buttons on the frame of the LCD screen. This allows the user more flexibility when holding the camcorder, especially in overhead or low angle shots. One Touch Wide Angle Shooting Easily Switch between 4:3 and 16:9 aspect ratios for shooting, with just the touch of a button. Picture Effects Get creative when recording or playing back your videos with Sony’s Picture Effect Modes. Effects available in camera and playback modes: Sepia, Monotone, Pastel and Mosaic. Picture Package™ Software Easily organize still images/video content, and turn them into stunning music videos using the supplied software. Program AE (Auto Exposure) Modes Program AE modes make recording easy even when filming in challenging situations. Choose from Portrait, Beach & Ski, Sports Lesson, Landscape, Spotlight or Sunset & Moon modes. Progressive Shutter System A mechanical shutter system that provides progressive scan performance while utilizing an interlaced scanning system. Digital still images will be sharp and clear with excellent definition. Su Fader Effects Enhance your personal videos by adding professional looking fader effects. Choose from Black, Overlap, White and Wipe. InfoLithium® Battery with AccuPower™ Meter System6 Charge the battery at anytime because unlike NiCad (Nickel Cadmium) batteries, Sony’s rechargeable Lithium Ion batteries are not subjected to a life shortening “memory effect". Sony’s exclusive AccuPower™ meter 7 displays the approximate battery time remaining in minutes, in either the viewfinder or on the LCD screen. USB 2.081 Interface Provides an easy way to connect your DVD Handycam Camcorder to the computer for fast transfer of video and still images to your computer for editing. The camcorder can also be used as an external DVD burner, convenient for making copies of your DVDs or burning edited movies. Specs: Imaging Device: 1/3" ClearVID™ CMOS Sensor Pixel Gross: 2100K Recording Media: 8cm DVD (DVD-R/DVDRW/DVD+RW) Recording and Playback Times: HQ: 20 min., SP: 30 min., LP 60 min. Video Actual: 1990K Pixels Still Actual: 3000K Pixels USB Streaming: N/A SteadyShot® Image Stabilization: Yes ( Super; Electronic) Accessory Shoe: Active Interface Shoe White Balance: Auto, Indoor, One-push, Outdoor Memory Stick PRO™ Media Compatibility: Yes, Tested to support up to 2GB77 media capacity; does not support high speed transfer function; does not support Access Control security function. Still Image Mode(s): JPEG Minimum Illumination: 5 Lux (0 Lux with Super NightShot® Infrared System) Low Light Capability: Super NightShot® Analog Audio/Video Input(s): Yes (Multi A/V) Analog Audio/Video Output(s): Yes (Multi A/V) Digital Audio/Video Input(s): Yes (via USB) Digital Audio/Video Output(s): Yes (via USB) USB Port(s): Yes (2.0 compliant) i.LINK® Interface: N/A Component Video (Y/Pb/Pr) Output(s): N/A Headphone Jack: N/A Microphone Input: Yes (thru Active Interface Shoe) Remote Jack: Yes (Mini Plug) S-Video Input(s): Yes (optional accessory) S-Video Output(s): Yes (optional accessory) LCD: 3.5" (211K Pixels Wide 16:9 Touch Panel SwivelScreen™ LCD Display): Lens Type: Carl Zeiss® Vario-Sonnar® T* Viewfinder: Color (123K Pixels) Docking Station: N/A Microphone: Yes (Built-in 5.1 Channel) 35mm Equivalent: 42.8-495mm (16:9 Camera Mode), 45-450mm (4:3 Camera Mode), 40.6- 406mm (16:9 Memory Mode), 37-370mm (4:3 Memory Mode) Aperture: f1.8-f2.9 Exposure: Touch Panel (24 steps) Filter Diameter: 30mm Focal Distance: 5.1-51mm Focus: Full Range Auto, Manual (Touch Panel) Progressive Shutter Mode: Yes Shutter Speed: Auto, 1/4-1/4000 (AE Mode) Optical Zoom: 10X Digital Zoom: 120X Power Consumption: 4.2W/4.6W (VF/LCD) Battery Type: InfoLithium® with AccuPower™ Meter System (NP-FP60) Power Requirements: 7.2V (battery pack); 8.4V (AC Adaptor) Limited Warranty: 1 Year Parts; 90 Days Labor Operating System Compatibility: Microsoft® Windows® 2000 Professional, XP Home, XP Professional Supplied Software: Picture Package™ ver. 1.8, Nero Express 6 Video Recording System: DVD-Video/DVD-VR/DVD+RW Video Video Signal System: NTSC color, EIA standards Analog-to-Digital Converter: Yes (Signal Convert) Weight: 1 lb. 6 oz (630g) with Disc and Battery Measurements: 2 5/8" x 3 5/8" x 5 3/8" (76 x 92 x 149mm) Heres pictures of the camera itself: Along with the camera are included 2 batteries, 1 which is a standard sony battery which should last up to 60 minutes (depends which record mode is chosen) and the other one is an after market battery which will last up to 180 minutes (depending on the record mode chosen). Also 2 memory sticks are included, one is a 256mb memory stick pro duo and the other is a 2gb memory stick pro duo high speed, which should hold over 1000 pictures at 4 megapixel mode. Also included are 2 memory stick pro duo adapter to a regular memory stick size along with a usb adapter so that the files can be synced into a computer via usb. The original camera box also comes with this bundle Also included are various lens size adapters plus 3 filters Also included in the package are 2 lenses, 1 is a wide angle (widescreen) lens which lets you see basically double on 1 screen (great for recording drag races at the track) and the other is a 2x zoom one, which basically has you zoomed without zooming. Also included are various camera battery pack chargers And a spindle of mini-dvd's is included, which should provide hours upon hours of video (theres about 20 in the spindle) Included are various adapter cables, power, usb, av etc... and a remote controller. Only the usb one was used once. A lens cleaning kit is also included, which comes in very handy. A carrying bag is also included which will carry all the equipment needed for the camera Various booklets/cd's/certificates: a up to 55 inch tall tripod in also included with a carrying bag: So here's everything included with the bundle: Asking prince is 1100$ O.B.O. , which is basically what the camera itself costs, not including all the extras. Thanks for looking. Pm or reply here if any questions or email [email protected]
1993 Eagle Talon Tsi Awd 5SPD - Teh Great White ![]() Chitownevo - Chicagoland's local evo forums |
Re: Sony DCR-DVD505 DVD Camcoder Bundle
Did you type all that shit or you Ctrl+C and Ctrl+P ?
GM FOR LIFE !! NEW 1997 Camaro z28 6 speed illa never going back to import , but killa alway be nice to any DSM he saw ![]() looking for 2002 Trans Am LSX UPGRATE 2010 !! 97 Camaro Z28 95 camaro lt1 1992 Pontiac Firebird v6 auto -sold - Pony 1998 Mustang GT 4.6L Manual. Black 1995 Eagle Talon TSI AWD Turbo manual R.I.P 1994 Mitsubishi Eclipse Manual gray -Sold 1997 Mitsubishi Eclipse RS Auto White - Sold |
Oh man, its a shame it uses mini dvd's. I am looking for one like that but with a harddrive instead...
-Brian
well, the info itself I copied from the sony website but the writeups about the pictured items is all me. The camera is pretty good becuase its kind of like killing 2 birds with one stone, you can take pictures or record dvd quality videos, or take pics while youre recording videos. Best part is that you can record movies in widescreeen, and with that wide angle lens, you can catch alot more. i remember recording cars at a racetrack, and some are faster than others, so the wideangle still catches the slow one stumbling in behind at the 1/4 mile. The tripod helps too. The only nuisance I would say would be that at highest quality you get only 20 mins per disc. Damian.
