Old 12-26-2006, 02:01 AM
jtvyper456's Avatar
jtvyper456 jtvyper456 is offline
Send a message via AIM to jtvyper456
95 3.4L Fuel Filter
looking at changing my fuel filter, I don't think it's been changed in 100k+ miles. So, when I take it out, do I need something to plug the line so all the fuel won't sputter out? Anything else I might need to do besides change the fuel filter, the plugs+wires are less than 6 months old, did those as soon as I got the car.
1995 Camaro
40 Series Flowmaster
2 Kicker Comp 05CVR 122 (Dual 2Ohm Voice Coils)
^Kicker ZX550.2 Amplifier^
Old 12-26-2006, 09:26 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: 95 3.4L Fuel Filter
Just have a catch pan ready and waiting and be sure to relieve the system pressure. And use line wrenches, one back up and to twist (loosen & tighten) and you'll be fine, the fuel will stop coming out.
Old 12-26-2006, 02:58 PM
jtvyper456's Avatar
How to relieve system pressure ? Never done this before!
1995 Camaro
Old 12-26-2006, 07:15 PM
stone_mound_camaro's Avatar
stone_mound_camaro stone_mound_camaro is offline
jus wait...many hours...probably with the battery unplugged... and dont twist your key in the ignition before you decide to start...
you can also put a rag on the end of the line and put a rubber band around it...to hold back some of that leakage
car audio guru...
Old 12-27-2006, 09:10 AM
wrightz28's Avatar
meh, 1/2 way ok stone. YEs letting it sit helps, no need ot to disconnect the battery. to get the majority out you could remove the gas cap and slowly depsress the the schrader valve on the fuel rail.
Me personally I like to dissable the fuel pump and crank the motor over a few times have it pull the pressure through.
Old 12-27-2006, 11:45 AM
CreepingDeath94 CreepingDeath94 is offline
I just crack it loose and let it spray all over me and the earth in a geyser of water table killing glee. The best way is to disable the fuel pump and crank the pressure out as wrightz28 said. Though every now and again a good gasoline bath is good for soul...
Old 12-31-2006, 05:51 PM
jtvyper456's Avatar
so I back it up on the ramps tonight, and the bolt that holds it in is dead stuck, any suggestions on getting it out? I wasn't turning the fuel filter itself, but the nut on the front of it, no avail.
1995 Camaro
Old 01-01-2007, 09:37 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
ok what bolt are you talking about? The one that holds the fuel filter in the little case? or the inlet or outlit bolt? try to get some penitrating oil like PB blaster and soak it down a coupple times and let is sit for about 30min.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 01-01-2007, 10:59 PM
jtvyper456's Avatar
Thanks, am going to get some tommorow .
1995 Camaro
