Old 12-24-2006, 09:26 PM
Beef66 Beef66 is offline
Bye bye clutch
well I noticed a few weeks ago that my clutch was starting to slip when I would get on it a little...well I was on my home tonight and it said goodbye by barely letting me get up the kill...Now if I just give it gas on a flat it will slip like crazy. So it looks like im getting a new clucth, and since im tackling that I think well just throw a tranny rebuild in the mix haha. So any recomendations on clutches?
Old 12-24-2006, 09:44 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Re: Bye bye clutch
Without any major mods an OEM one will be fine.
Check this out:
http://www.3sx.com/store/comersus_li...?idCategory=29
Old 12-24-2006, 11:37 PM
Re: Bye bye clutch
Ive been looking around for a while now...I wanted to do something a a little more than oem just in case I end up doing something else to the stealth ( TT swap next year possible) so...whats the work on RPS?
http://www.dynamicracing1.com/custom...cat=115&page=1
Or possible the SPEC stage one
Old 12-24-2006, 11:57 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Bye bye clutch
I personally love my ACT.
Old 12-25-2006, 12:41 AM
Morphius289's Avatar
Morphius289 Morphius289 is offline
Re: Bye bye clutch
It doesn't "ACT" up a lot does it?
I've heard good things about both ACT and RPS. I'd go for whichever one is cheaper I guess.
Black 1997 3000GT
Originally Posted by Igovert500
[01:05] Igovert500: scrwe his method
[01:05] Igovert500: too much crap
[01:06] Igovert500: i just jam a garden hose in there
[01:06] Igovert500: and put it on high flow
[01:06] Igovert500: go the opposite direction too
[01:06] Igovert500: so it clears out more shit
18 and out of debt - member #1
Old 12-25-2006, 06:12 AM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
Re: Bye bye clutch
i got my southbend clutch 3 years ago. since i've abused it, and its still in the runnings. the clutch is really really quick though. as soon as you let up off of it(just barely), if your not giving it some gas its gonna stall
Old 12-26-2006, 05:16 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Bye bye clutch
how many miles are on your tranny/car? unless you have grinding noises, its not worth a rebuid. a clutch job is easy, but taking apart the tranny and rebuilding it is a whole different story.
you can upgrade your NA clutch if you want, but its really not worth it. a lot of ppl do it b/c they think they need to, but its really just a waste of money. anything more than OEM quality is just overkill. but if you DO actually end up doing the TT conversion, then you WILL need a beefier clutch. so its a good thing that you're planning for the future, but just keep in mind what is necessary and what is extraneous.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 12-26-2006, 11:43 PM
Re: Bye bye clutch
I just rolled over 117k the other day w/ the origional clutch...Believe me my tranny is a fan of grinding, started in 3rd, then second, now third even shifting almost anytime...I ended up ordering the RPS clutch tonight so I can get it back on the road...The tranny rebuild is going to have to wait til the spring, because of $$$...Im not planning on tackling that myself though, im getting it built by a shop and then putting it back in.
Old 12-27-2006, 05:58 PM
youngvr4's Avatar
STREET RACING GURU
Re: Bye bye clutch
synchro's grinding...just order some blocking rings and tell them to install them
i dont think there's any need to rebuild the whole thing
