Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 12-24-2006, 10:11 PM
EvanM07 EvanM07 is offline
1988 Ranger Horn doesn't work...
I bought a 1988 Ranger from a friend of mine. He was doing a lot of work on it before i bought it. It is missing some fuses and my horn doesn't work. All the lights and every thing works and it runs but i have no horn. The cover to the fuse panel is missing and my friend can't fond it anywhere. Does anyone have a picture of an '88 fuse panel cover or be able to rell me what to do or maybe a diagram?
Please help!
Old 12-29-2006, 09:54 PM
4x4grey88's Avatar
4x4grey88 4x4grey88 is offline
Re: 1988 Ranger Horn doesn't work...
Have you tried to see if the horn actually works? You can jump a wire to the horn leads from the battery (of course it should sound). Do you have power to the horn itself via the OEM connections? Have you also checked to see if there is power to the fuse?
Let us know.
www.jeepforum.com; www.socalultimate4x4.com
1998 Wrangler (replaced my 88 XJ)
21' Mini Winnie (replaced my Pace Arrow)
Old 12-30-2006, 07:10 AM
e_powers e_powers is offline
here is the object of desire....
http://www1.autozone.com/servlet/UiB...3d800f941d.jsp
starting to love my 93 ranger w/3.0 5 speed.
Old 12-30-2006, 11:33 AM
butch h butch h is offline
With a test light & power off check all fuses,the horn is powered at all times,so if you find a bad fuse(you can probe the back of both sides of the fuse with it in place)it's a 20 amp fuse that belongs in there,replace & see.The '90 Ranger uses a horn relay IF you have cruise control. The relay would be located under IP, to right of steering wheel.
