Old 12-24-2006, 07:46 PM
buick24 buick24 is offline
Question headlight adjustment??
I have a 95 lesabre and the headlights need adjusted badly. I cannot figure out which screws adjust the headlamp. I don't want to adjust the wrong ones and make it worse. If anyone can tell me which ones do what and if they had pictures this would be great. I have a haynes repair manual but they do not show on this model year. thanks
Old 12-24-2006, 08:55 PM
mcqueary mcqueary is offline
Re: headlight adjustment??
I looked in the 95 FSM. The pictures are not very good but here's what it says.
"Horizontal aim is done by an adjusting screw on the outer side of the headlight assembly. Vertical aim is done by an adjusting screw in the top center of the assembly." from page 8B-11 of 95 Lesabre FSM.
I hope this helps.
Old 12-24-2006, 11:50 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
On my 89, there are access holes for using a T15 torx screwdriver on a couple of adjustment screws. Just get the car on a level surface, point the lights at a flat wall and aim away.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 12-25-2006, 09:10 AM
imidazol97 imidazol97 is offline
AF -Advisor
To add my 10Cents worth, I find a lightly traveled road and put a towel on hood over one side's headlights and then adjust the other to where I want it to shine on the road. Then I reverse the towel to adjust the other light.
I watch when driving when it's foggy to see where the main beam goes from each light, then I readjust.
Old 12-25-2006, 08:13 PM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
2 large black knobs are used to adjust the headlights in the '95. No tools needed
I parked mine in front of my garage at night and shined them on the door to adjust that way.
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
