Old 12-24-2006, 12:40 PM
BiGwiLLswiLLy BiGwiLLswiLLy is offline
Send a message via AIM to BiGwiLLswiLLy
Pain in the A$$
O.K i have a 90 civic base model, swapped out the motor put a LS in caouldent stand 4 gears an 90 hp...well first had a stripped oil pan bolt and by the hole it had a inprefection so even with a oversized plug still leaked so put in another pan i had, then bad alternator, so put another one in, now that i have it running and driving, check engine light comes one code 17 speed sensor, but my Speedo works...any ideas on this one? also now my front brakes are locked up and they worked fine before the swap dont know what coulda happened there..guess i gotta look into that when i get a chance now, possible brake lines? but both bad?
Old 12-24-2006, 12:44 PM
Re: Pain in the A$$
o and to top it off also needa a radiator when i did the swap noticed the old one was real bad dont know how it was workin in the car before...and i couldent find no exhaust bolts for the down pipe...the worst part is i thought the wiring and the welding my shift linkages was gonna be the pain...they both worked out good with no problems...
Old 12-24-2006, 01:16 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: Pain in the A$$
Did you recently swap out guage clusters? I did this once and had a defective speed sensor in the cluster. My speedo worked but i was getting code 17. Try another speedo portion of the cluster and see if it erases that code. You may have to swap your VSS in your tranny.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 12-24-2006, 04:17 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: Pain in the A$$
Nah the 90's had a mechanical drive on the tranny. Check to make sure the VSS wire is even connected to both the cluster and the ECU, and then try swapping them out.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 12-24-2006, 06:08 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
Re: Pain in the A$$
dude try to repost and make some sense..u got alot of typos and confuse me..94+ LS's were VSS what yr LS do u got and what is the the problem in english..? not being cocky...without a paragraph whats wrong
Old 12-24-2006, 07:02 PM
Re: Pain in the A$$
its a 90 ls and the cluster is the orignal in the car...
Old 12-24-2006, 09:05 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: Pain in the A$$
try resetting the ECU.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 12-25-2006, 05:47 PM
Re: Pain in the A$$
good point ill try resetting it, as for the brakes fixed that...
