Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 12-24-2006, 07:53 AM
riverwind riverwind is offline
97 Sebring Dash Lights
The dash lights quit working on my Sebring. I checked the fuse and it is ok, I pulled the insstrument cluster thinking maybe I would see something there, but I didn't. I pulled a couple of the lights and the bulbs are ok.
Is there something I am missing. I sure hate the thought of tracing the wiring backwards, I do not have a wiring diagram.
Thanks,
Kenny
Old 12-31-2006, 05:39 PM
hundahunta hundahunta is offline
Re: 97 Sebring Dash Lights
Instrument Cluster- C2 Cav Circuit Function
1 L39 18lb Fog Lamp Siwtch Output
10 E2 18or/yl Panel Lamps Driver Ground
11 Z1 18bk/or Ground
12 G6 20gy Oil Pressure Switch Sense
13 G19 20lg/or Abs Warning Lamp Driver
2 L61 18lg/tn Left Turn Signal
3 D2 20wt/bk (with Traveler) Traveler Ccd Bus (-)
4 D1 20vt (with Traveler) Traveler Ccd Bus (+)
5 F18 20lg/bk Fused Ignition Siwtch Output (run/start)
6 G9 22gy/db Red Brake Warning Lamp Driver
7 D2 20wt/db Ccd Bus (-)
8 D1 20vt/br Ccd Bus (+)
9 - -
Instrument Cluster -c1 Cav Circuit Function (red)
1 L60 18tn/br Right Turn Signal
10 - -
11 - -
12 - -
13 G78 20tn/bk Trunk Ajar Switch Sense
2 F11 18rd/vt Fused Ignition Switch Ouptu (off/run/start)
3 - -
4 Z2 18bk/lg Ground
5 F33 20pk/rd Fused B(+)
6 - -
7 G69 20bk/or (with Vtss) Vtss Indicator Lamp Driver
8 G29 20bk/tn Washer Fluid Switch Sense
9 - -
