Old 12-23-2006, 03:34 AM
paula hulet paula hulet is offline
94 park ave dying
it started out at first when i would try and start it. after alittle while it will start up. now it is also dying when i am driving down the road. it acts like it is not getting gas when it does not start.
Old 12-23-2006, 09:22 AM
maxwedge maxwedge is offline
A990 racer
Re: 94 park ave dying
Welcome to AF. This broad a question requires some basic diagnostics, do you have good fuel pressure on the no start, sufficient spark?
Old 12-26-2006, 09:40 PM
beckyboodles83 beckyboodles83 is offline
I have a similar problem. Mine started dying when I brake. I had the fuel injectors cleaned, thinking it may be clogged. It did seem to run smoother, but it died again yesterday. Today, the service engine soon light has come on twice but the car didn't die. Any ideas?
Old 12-26-2006, 11:43 PM
HondaManDan's Avatar
HondaManDan HondaManDan is offline
Send a message via AIM to HondaManDan
Time for a new fuel-pump and fuel-lines fellas.... First, go to the parts store and get a replacement fuel-filter first... see if that frees up the line... if not, you've got a major problem between the fuel tank and the injectors.
Before you start the car, turn the ignition ON and listen to the back-seat. It should hum a little (the fuel pump is directly under it). If you hear NO, LOW, or the hum STARTS then STOPS... it's time for a new pump.
Look under the car and see if you can smell fuel anywhere as well.
Good luck.
Dan
95' Buick Park Ave... hell yeah.
Old 12-27-2006, 12:04 AM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Get a fuel pressure gauge after you replace the fuel filter. A good pump ought to run around 40PSI.
Another possibility would be a faulty coil/icm.
Get those diagnostic codes in the mean time!
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
