Old 12-23-2006, 12:32 AM
kaspr kaspr is offline
Exhaust dent: affecting power?
A couple of years ago I hit a rock when my exhaust was hanging low (before I got it re-fastened), and it put this sizable dent in my exhaust toward the back. I would say the diameter of the exhaust is restricted 30-40% at the point where the rock hit. Do you think this is affecting performance in any way? My power is less than it used to be, but I think it might be a fuel pressure problem (I'm replacing the pressure regulator).
P.S. How do I attach pictures?
Old 12-23-2006, 01:24 AM
HondaManDan's Avatar
HondaManDan HondaManDan is offline
Send a message via AIM to HondaManDan
Re: Exhaust dent: affecting power?
kaspr,
Yes, this pinch is hindering performance, especially if its BEFORE the muffler. It shouldn't make too much difference, but it'll cause excess back-pressure. The sensors in the car can read this and is probably throwing a code to the motor.
Change the exhaust before the pressure regulators. See if it helps anything.
In order to post a image you can either put [img] IMAGE LINK [/img] or use an <a href> HTML code to post it.
http://concours.smugmug.com/photos/643933-M-1.jpg
put that inside the [img][/img] brackets and you get...
95' Buick Park Ave... hell yeah.
Old 12-25-2006, 01:01 AM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Depends on the size of the ding. If it isn't much, then it shouldn't make enough of a difference on the backpressure.
You probably have other problems that are resulting in the loss of power, especially if you haven't had this loss of power until recently.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 12-29-2006, 10:21 PM
Actually, this happened a few years ago, which is about how long I've been putting up with reduced power. Here's the pics that I've finally uploaded. Thanks for the instructions! Would you say that this is a significant ding?
Old 12-29-2006, 11:24 PM
That IS a significant ding, plus it's right in the bend (where flow is restricted to begin with). Fix it. You'll notice a difference right away.
Dan
