Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 12-22-2006, 11:31 PM
amboldo amboldo is offline
Send a message via AIM to amboldo
Question coolant stupid question
how do you change the antifreeze in a crown vic? stupid question I know! I cant find the drain plug,and after it's empty how do I refill it? from the resevoir bottle?how about bleeding the air out of the system? any and all help appreciated. thanks,dave
Old 12-24-2006, 01:44 AM
KimMG KimMG is offline
AF - Advisor
Re: coolant stupid question
Year and engine would be helpful.
Old 12-25-2006, 01:32 PM
sorry about that is a 94 crown vic lx 4.6l
Old 12-25-2006, 02:29 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Drain plug is on the drivers side bottom. We uaually replace the thermostat at the same time and fill the block back through the intake, install thermostat and top hose. Then fill reservoir and allow to run intil normal operating temp. Shut engine off for a few minutes and air will bleed to the reservoir. Refill as needed and start vehicle again until normal operating temp again. Check for leaks and be on your way. Be sure thermostat is opening properly before driving.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
