Old 12-22-2006, 09:03 PM
Cbierniat's Avatar
Cbierniat Cbierniat is offline
Pulley noise?
93 Lumina got what i believe pulley noise...when in park it does not do it same with neutral only in drive which pulley could it be if it is even a pulley? I had a smiliar problem with my GTP but i just replaced all of them and problem solved but im trying to save $ on this one.
Thanks
Old 12-23-2006, 12:52 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Pulley noise?
Um, try maybe a transmission/torque converter problem here. If it goes away in park and neutral, its not a pulley. The pulleys are spinning whenever the motor is running.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 12-23-2006, 01:29 AM
Cbierniat's Avatar
Re: Pulley noise?
What other symptoms would my trans converter cause?....cuz it sounds like its coming from the passenger side of the engine but i know the trans is near the front of the car....thanks...
Old 12-23-2006, 06:59 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Pulley noise?
The load of being in gear could take the idle speed down to the threshold where the noise can be heard.....what kind of noise is it (chatter, clicking, sqeal, hiss, etc)?
Could just be the belt itself too...they get stuff imbedded in them that produces weird sounds at low rpm's...little flecks of rock and other grit stuck in the ribbed side will make light clicking chatter....when it idles, does the belt tensioner arm stay fairly still, or does it hop around excessively? The arm will usually start to jump around pretty wildly when for example the bearing in the tensioner pulley starts going bad, and you can also look straight down at the belt and make sure there is no tip-in where the arm is making the belt run slightly off-track, this will produce a constant hiss or squeal at low speeds...in that case, the tensioner arm itself would need replacement.
