Old 12-22-2006, 04:42 PM
water_sprite water_sprite is offline
92 Accord brake light problem
Hoping you can help.....The brake lights on the passenger side are out.....The bulbs look good, tho....
Tried to find the fuse for brake lights and can't find on labeled for brakes.....Can someone tell me which fuse it is?,....
Thanks!
Old 12-22-2006, 04:53 PM
somick's Avatar
somick somick is offline
Re: 92 Accord brake light problem
Check all grounds.
If the bulb looks OK test it with the ohmmeter. It still may be bad.
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 12-22-2006, 06:02 PM
Igovert500's Avatar
blue + red light magnet
Swap the bulb with the other side. See if hte bulb is actually the problem. Quick adn easy way.
If it were a fuse, chances are both brake lights would be out. Potentially even more. Every car I've ever owned has had most of hte lights on the same fuse. At least both brakes lights are usually on teh same fuse. So if only one light is out, I'd guess bulb or ground wire as well.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 12-22-2006, 07:32 PM
Makes sense....Don't know why I didn't think of it.....Thanks, I'll try it tomorrow....
Merry Christmas
