Old 12-22-2006, 03:57 PM
Talk is Cheap Talk is Cheap is offline
ignition switch replacement
My 03 Silverado was broken into, they tried to hotwire and drive off with it, for some reason they weren't able to but now I have a broken switch stuck in the on position, no way to do anything with it. Where can I find replacement for it that includes the door locks, at a good price and how do I install them, I think I can do the door locks but its the ignition I'm not too confident about. Any input is greatly appreciated.
Old 12-22-2006, 04:26 PM
maxwedge maxwedge is offline
A990 racer
Re: ignition switch replacement
Welcome to AF. Remember the doors locks will have to be coded to your key they come uncoded number one, number two, how much experience do you have with disassembling the air bag system and upper column to replace the key cylinder? Dealer parts here the best way.
Old 12-22-2006, 04:42 PM
twistedtech twistedtech is offline
I'm with max. Remember this in the front of your mind,AIR BAG AIR BAG BOMB.If your short in the expierience department you may not want to try this,but with the ability to follow directions closely and have the patience,not sure what they are myself, you might do it.The cyl swap is not a big deal it's the bomb in front of you.The reason i said to keep it in the front of your mind is if you don't do it right,that's where it will be.
If it ain't broke.......screw with it till it is.
Even at a Mensa convention,
Someone's the dumbest person in the room.
