Go Back   Automotive Forums Car Chat > Honda > RSX
Old 12-22-2006, 01:50 PM
chris87 chris87 is offline
Should i buy?
I went and looked at an 2002 rsx-s. The guy will sell it for 10,000 but the only thing is the milage. The car has 130,000 miles on it, which are from driving on the interstate. Is there anything i should know about buying a car with this much milage on it? Please give me some advice.
Old 12-23-2006, 02:19 PM
RSX-S777's Avatar
RSX-S777 RSX-S777 is offline
Re: Should i buy?
The price is more or less in line with private sale value. I wouldn't worry about the motor's integrity unless he modified it at all. Make sure the pads have meat, the battery and belts look good and do a little test drive clutch test. Make sure he has the radio code, too. If everything checks out and you like it, buy it. Good luck.
I've got a fever. And the only prescription is more cowbell...
Old 12-23-2006, 09:25 PM
Re: Should i buy?
The car is completely stock. He put new brakes on it. And could you tell me more about this radio code.
Old 12-24-2006, 02:56 PM
RSX-S777's Avatar
Re: Should i buy?
It's a security code. Anytime you have to disconnect the battery (or whatever) you have to enter the code into the radio to be able to use it. Sometimes owners lose it and it can be a real pain in the ass to get the code. You can get it from the dealer for $. Shouldd be in the leather owner's binder on a small white card. No big deal- but will make your life easier.
Clutch ok?
Old 12-24-2006, 06:11 PM
Re: Should i buy?
The clutch seem ok. I am going to drive it again tuesday and make my final decision. Ill see if i can get the price lowered too.
Old 12-24-2006, 10:20 PM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
Re: Should i buy?
its a honda man the most reliable car in the world. I would say go for it
10gs is kinda of high though i would ask him about 8
MODS
, 2g pistons, cyclone intake manifold, ported 1g head, 60mm tb, greddy type s bov, apex-i n1 exhaust , ngk spark plugs, 3 angle valve job, autometer boost/vac, autometer air/fuel ,autometer oil pressure ,cross drilled rotors ,turbonetics boost controller ,air filter ,remove dump tube, 14b turbo
and the ac still doesn't work and its been almost 3 years
Old 12-24-2006, 11:57 PM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
Re: Should i buy?
8,500 sounds like a good deal to me. goodluck.
-tony-
2000 honda s2000
