Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 12-21-2006, 11:33 PM
backayrdauto backayrdauto is offline
Exclamation replaced EGR valve
I have a 99 saturn sl (single overhead cam). I have the code p0401. I have already replaced the EGR valve and I cannot get the code to disapear. Can anybody help? Is there a line or hose that could clog with carbon?
Thank you for your time to read this.
Old 12-23-2006, 10:06 AM
Cat Fuzz Cat Fuzz is offline
Re: replaced EGR valve
The port in the head may need to be cleaned out. Could have been your problem all along. Also, you need to clear the code with an OBDII scan tool or it may take several drive cycles for it to go away on its own, if the problem is fixed, that is.
Old 12-25-2006, 09:00 PM
answerman answerman is offline
Also might check for cracked or unhooked vacume lines going to EGR solenoid.
Old 12-26-2006, 11:37 AM
Luke. Luke. is offline
Fm BackayrdAuto
I believe that you car requires an OBD-II scanner (((>On Board Diagnostic<))) Your EGR may be working perfectly, but the system's memory has not been cleared.
1997 Buick LeSabre Limited, with Grand Touring Suspension (72,925 miles) with UIM/EGR Stovepipe leakage issues resolved/repaired
& 1995 Saturn SL2 (498,125 miles) as of 6/19/07
Old 12-26-2006, 01:04 PM
ksion15's Avatar
ksion15 ksion15 is offline
make sure you got the right part. 96-99 have a different flow rating than the 00-up. if you have the wrong part, it will fail the flow test.
K.S.
Service Technician
Saturn of XXXXXX
ASE Certified
GM/Saturn Certified
